Types of Air Compressors
The three basic types of air compressors are
  • reciprocating
  • rotary screw
  • rotary centrifugal
These types are further specified by:
  • the number of compression stages
  • cooling method (air, water, oil)
  • drive method (motor, engine, steam, other)
  • lubrication (oil, Oil-Free where Oil Free means no lubricating oil contacts the compressed air)
  • packaged or custom-built
Reciprocating Air Compressors
Reciprocating air compressors are positive displacement machines, meaning that they increase the pressure of the air by reducing its volume. This means they are taking in successive volumes of air which is confined within a closed space and elevating this air to a higher pressure. The reciprocating air compressor accomplishes this by a piston within a cylinder as the compressing and displacing element.
Single-stage and two-stage reciprocating compressors are commercially available.
  • Single-stage compressors are generally used for pressures in the range of 70 psig to 100 psig.
  • Two-stage compressors are generally used for higher pressures in the range of 100 psig to 250 psig.
Note that
  • 1 HP ~ up to 4 CFM at 100 psi
and that 1 to 50 HP are typically for reciprocating units. Compressors 100 hp and above are typically Rotary Screw or Centrifugal Compressors.
The reciprocating air compressor is single acting when the compressing is accomplished using only one side of the piston. A compressor using both sides of the piston is considered double acting.
Load reduction is achieved by unloading individual cylinders. Typically this is accomplished by throttling the suction pressure to the cylinder or bypassing air either within or outside the compressor. Capacity control is achieved by varying speed in engine-driven units through fuel flow control.
Reciprocating air compressors are available either as air-cooled or water-cooled in lubricated and non-lubricated configurations and provide a wide range of pressure and capacity selections.
Rotary Screw Compressors
Rotary air compressors are positive displacement compressors. The most common rotary air compressor is the single stage helical or spiral lobe oil flooded screw air compressor. These compressors consist of two rotors within a casing where the rotors compress the air internally. There are no valves. These units are basically oil cooled (with air cooled or water cooled oil coolers) where the oil seals the internal clearances.
Since the cooling takes place right inside the compressor, the working parts never experience extreme operating temperatures. The rotary compressor, therefore, is a continuous duty, air cooled or water cooled compressor package.
Rotary screw air compressors are easy to maintain and operate. Capacity control for these compressors is accomplished by variable speed and variable compressor displacement. For the latter control technique, a slide valve is positioned in the casing. As the compressor capacity is reduced, the slide valve opens, bypassing a portion of the compressed air back to the suction. Advantages of the rotary screw compressor include smooth, pulse-free air output in a compact size with high output volume over a long life.
The oil free rotary screw air compressor utilizes specially designed air ends to compress air without oil in the compression chamber yielding true oil free air. Oil free rotary screw air compressors are available air cooled and water cooled and provide the same flexibility as oil flooded rotaries when oil free air is required.
The centrifugal air compressor is a dynamic compressor which depends on transfer of energy from a rotating impeller to the air.
Centrifugal compressors produce high-pressure discharge by converting angular momentum imparted by the rotating impeller (dynamic displacement). In order to do this efficiently, centrifugal compressors rotate at higher speeds than the other types of compressors. These types of compressors are also designed for higher capacity because flow through the compressor is continuous.
Adjusting the inlet guide vanes is the most common method to control capacity of a centrifugal compressor. By closing the guide vanes, volumetric flows and capacity are reduced.
The centrifugal air compressor is an oil free compressor by design. The oil lubricated running gear is separated from the air by shaft seals and atmospheric vents.
Gases and Compressed Air
Air - SCFM versus ACFM and ICFM
Actual air compressor capacity (ACFM) vs. standard air capacity (SCFM) and inlet air capacity (ICFM).
Air Compressor - Power Cost per Year
Yearly power cost for operating an air compressor.
Air Compressors - Maximum Air Flow vs. Inlet Pipe Size
Inlet pipe size and maximum air flow.
Compressed Air - Storage Volume
Calculate the storage volume of compressed air or other gases.
Compressed Air Receivers
Calculating air receivers capacity.
Pumps vs. Compressors, Blowers and Fans
The difference between pumps, compressors, blowers and fans.
Rating of Air Compressors and Air Equipment
Common rating terms for air flow capacity are ICFM, FAD, ANR, SCFM or nl/min.
Calculate specific work done by pumps, fans, compressors or turbines.
