Since temperature and air pressure varies from place to place a standard reference is necessary for comparing the testing and the documentation of chemical and physical processes.
Note! There is a variety of alternative definitions for standard reference conditions of temperature and pressure. STP, NTP and other definitions should therefore be used with care. It is always important to know the reference temperature and reference pressure for the actual definition used.
STP is commonly used to define standard conditions for temperature and pressure which is important for the measurements and documentation of chemical and physical processes:
- STP - Standard Temperature and Pressure - is defined by IUPAC (International Union of Pure and Applied Chemistry) as air at 0 oC (273.15 K, 32 oF) and 105 pascals (1 bar).
- STP - commonly used in the Imperial and USA system of units - as air at 60 oF (520 oR, 15.6 oC) and 14.696 psia (1 atm, 1.01325 bara)
- also named "1 Standard Atmosphere"
- At these conditions, the volume of 1 mol of a gas is 23.6442 liters.
- These conditions are the most commonly used to define the volume term Sm3 (Standard cubic meter)
Note! The earlier IUAPC definition of STP to 273.15 K and 1 atm (1.01325×105 Pa) is discontinued. However,
- These conditions are still the most commonly used to define the volume term Nm3 (Normal cubic meter)
- At these conditions, the volume of 1 mol of a gas is 22.4136 liters.
1 Pa = 10-6 N/mm2 = 10-5 bar = 0.1020 kp/m2 = 1.02×10-4 m H2O = 9.869×10-6 atm = 1.45×10-4 psi (lbf/in2)
NTP is commonly used as a standard condition for testing and documentation of fan capacities:
- NTP - Normal Temperature and Pressure - is defined as air at 20 oC (293.15 K, 68 oF) and 1 atm ( 101.325 kN/m2, 101.325 kPa, 14.7 psia, 0 psig, 29.92 in Hg, 407 in H2O, 760 torr). Density 1.204 kg/m3 (0.075 pounds per cubic foot)
- At these conditions, the volume of 1 mol of a gas is 24.0548 liters.
Example - Fan Pressure Increase
A fan that produce a static pressure of 3 in H2O (a good average value) - will increase the absolute air pressure by
((3 in H2O) / (407 in H2O)) (100 %) = 0.74 %
SATP - Standard Ambient Temperature and Pressure
SATP - Standard Ambient Temperature and Pressure is also used in chemistry (International Union of Pure and Applied Chemistry - IUPAC) as a reference:
- SATP - Standard Ambient Temperature and Pressure is a reference with temperature of 25 oC (298.15 K) and pressure of 100.000 kPa.
- At these conditions, the volume of 1 mol of a gas is 24.4651 liters.
ISA - International Standard Atmosphere
ISA - International Standard Atmosphere is used as a reference to aircraft performance:
- ISA - International Standard Atmosphere is defined to 101.325 kPa, 15 oC and 0% humidity.
ICAO Standard Atmosphere
Standard model of the atmosphere adopted by the International Civil Aviation Organization (ICAO):
- Atmospheric pressure: 760 mmHg = 14.7 lbs-force/sq inch
- Temperature: 15 oC = 288.15 K = 59 oF
• Basics
• Ventilation Systems
Density and specific volume of air varies with elevation above sea level.
Air - Psychrometric Chart for Standard Atmospheric Conditions - Imperial Units
Psychrometric chart to analyze air properties, including temperature, humidity, enthalpy, and dew point at barometric pressure 29.921 inches of Mercury and temperature ranging 20oF to 120oF.
Air Ducts - Major Friction Loss vs. Temperature and Pressure
The influence of temperature and air pressure on major friction loss.
Atmospheric Pressure vs. Elevation above Sea Level
Elevation above sea level - in feet and meter - with barometric and atmospheric pressure - inches mercury, psia, kg/cm2 and kPa.
Barometer - Altitude Compensation
Elevation compensating manometer.
Density of Gases
Fan Affinity Laws
The affinity laws can be used to calculate resulting volume capacity, head or power consumption when speed or wheel diameters are changed.
Fans - Volume Flow, Pressure Head and Power Consumption vs. Air Temperature and Density
The temperature and density of the air influences on the volume flow, pressure head and power consumption in a fan.
Gases - Specific Gravities
Specific gravities of air, ammonia, butadiene, carbon dioxide, carbon monoxide and some other common gases.
Indoor Conditions - Summer or Winter
Recommended indoor design conditions summer or winter.
International standard atmosphere in elevation -2000 to 30000 metre - pressure, temperature, density, viscosity, thermal conductivity and velocity of sound.
Convert between pressure units like Pa, bar, atmosphere, pound square feet, psi and more.
Pressure Units Converter
Convert from kPa to psi and inches of Water and Mercury.
Thermocouples
Thermocouples - types, principles and temperature ranges.
U.S. Standard Atmosphere: Temperature, Pressure, and Air Properties vs. Altitude
Properties of the US standard atmosphere ranging -5000 to 250000 ft altitude.
