Benzene, C6H6, is a clear colorless to light-yellow liquid, flammable with a petroleum-like, aromatic odor.
Benzene is less dense than water and is slightly soluble in water . Hence it floats on water . Benzene vapor is heavier than air. Benzene causes central nervous system damage acutely and bone marrow damage chronically and is carcinogenic. It was formerly used as parasiticide.
Benzene is present in crude oils and is a product of oil-refining processes. There are limitations on the content of benzene in gasoline. In industry benzene is used as a solvent, as a chemical intermediate, and is used in the synthesis of numerous chemicals.
The phase diagram of benzene is shown below the table.
Chemical, physical and thermal properties of benzene :
Values are given for liquid at 25 oC (77 oF, 298 K) and 1 bara, if not other phase, temperature or pressure given.
For full table with Imperial Units - rotate the screen!
Property Value Unit Value Unit Value Unit Value Unit
Autoignition temperature 771 K 498 °C 928 °F
Boiling Point 353.2 K 80.08 °C 176.1 °F
Critical density 4.00 mol/dm3 312 kg/m3 0.606 slug/ft3 19.5 lb/ft3
Critical pressure 4.89 MPa=MN/m2 48.9 bar 48.3 atm 709 psi=lbf/in2
Critical temperature 562.0 K 288.9 °C 551.9 °F
Critical volume 250 cm3/mol 0.00320 m3/kg 1.65 ft3/slug 0.0513 ft3/lb
Density 11185 mol/m3 873.7 kg/m3 1.695 slug/ft3 54.54 lb/ft3
Flammable, gas and liquid yes
Flash point 262 K -11 °C 12 °F
Gas constant, individual, R 106.4 J/kg K 0.02957 Wh/(kg K) 636.5 (ft lbf/slug °R) 19.78 (ft lbf/lb °R)
Gibbs free energy of formation (gas) 130 kJ/mol 1664 kJ/kg 716 Btu/lb
Heat (enthalpy) of combustion (liquid) -3267.6 kJ/mol -41832 kJ/kg -18.0 Btu/lb
Heat (enthalpy) of formation (gas) 82.9 kJ/mol 1061 kJ/kg 456 Btu/lb
Heat (enthalpy) of formation (liquid) 49 kJ/mol 627 kJ/kg 270 Btu/lb
Heat (enthalpy) of fusion at 42°F/5.85°C 9.9 kJ/mol 127 kJ/kg 54.49 Btu/lb
Heat (enthalpy) of sublimation, at 42°F/5.85°C 45 kJ/mol 576 kJ/kg 248 Btu/lb
Heat (enthalpy) of evaporation 33.8 kJ/mol 433 kJ/kg 186 Btu/lb
Specific heat capacity, Cp (gas) 82.4 J/mol K 1.05 kJ/kg K 0.252 Btu/lb°F or cal/g K
Specific heat capacity, Cp (liquid) 133 J/mol K 1.70 kJ/kg K 0.407 Btu/lb°F or cal/g K
Specific heat capacity, Cp (solid) at 32°F/0°C 118 J/mol K 1.51 kJ/kg K 0.361 Btu/lb°F or cal/g K
Specific heat capacity, Cv (liquid) 92.8 J/mol K 1.19 kJ/kg K 0.284 Btu/lb°F or cal/g K
Ionization potential 9.24 eV
log KOW (Octanol/Water Partition Coefficient) 2.13
Melting point 278.708 K 5.6 °C 42.0 °F
Molecular Weight 78.112 g/mol 0.17221 lb/mol
Solubility in water, at 25°C 1.79 mg/ml
Sound velocity 1330 m/s 4362 ft/s 2979 mi/h
Specific Gravity (gas) (relativ to air) 2.77
Specific Gravity (liquid) (relativ to water) 0.88
Specific Heat Ratio (liquid) - CP/CV 1.43
Specific Volume 0.0000894 m3/mol 0.00114 m3/kg 0.590 ft3/slug 0.0183 ft3/lb
Standard molar entropy, S° (gas) 269 J/mol K 3.44 kJ/kg K 0.82 Btu/lb °F
Standard molar entropy, S° (liquid) 173 J/mol K 2.21 kJ/kg K 0.53 Btu/lb °F
Standard molar entropy, S° (solid), at 1 bara 45.56 J/mol K 0.58 kJ/kg K 0.14 Btu/lb °F
Surface tension 28.2 dynes/cm 0.02822 N/m
Thermal Conductivity 0.143 W/m°C 0.0826 Btu/hr ft °F
Triple point pressure 4.80E-03 MPa=MN/m2 4.80E-02 bar 4.74E-02 atm 6.96E-01 psi=lbf/in2
Triple point temperature 278.7 K 5.6 °C 41.99 °F
Vapor (saturation) pressure 0.0128 MPa=MN/m2 96 mm Hg 0.126 atm 1.86 psi=lbf/in2
Viscosity, dynamic (absolute) 0.6040 cP 405.9 (lbm/ft s ×10-6) 12.61 (lbf s/ft2 ×10-6)
Viscosity, kinematic 0.691 cSt 7.4 (ft2/s ×10-6)
See also the following documents for changes in benzene properties with changes in pressure and temperature:
as well as Thermophysical properties of: Acetone, Acetylene, Air, Ammonia, Argon, Butane, Carbon dioxide, Carbon monoxide, Ethane, Ethanol, Ethylene, Helium, Hydrogen, Hydrogen sulfide, Methane, Methanol, Nitrogen, Oxygen, Pentane, Propane, Toluene, Water and Heavy water, D2O.
Benzene is a liquid at standard conditions. However, if heated it becomes a gas, and when cooled it becomes a solid. The phase diagram for benzene shows the phase behavior with changes in temperature and pressure. The curve between the critical point and the triple point shows the benzene boiling point with changes in pressure. It also shows the saturation pressure with changes in temperature.
Boiling Points of Fluids
Densities
Fluid Mechanics
Material Properties
Melting and Freezing Points
Thermodynamics
Viscosities
Acetylene - Thermophysical Properties
Chemical, Physical and Thermal Properties of Acetylene.
Argon - Thermophysical Properties
Chemical, Physical and Thermal Properties of Argon.
Online calculator, figures and table showing density and specific weight of benzene, C6H6, at temperatures ranging from 5 to 325 °C (42 to 620 °F) at atmospheric and higher pressure - Imperial and SI Units.
Benzene Gas - Specific Heat vs. Temperature
Specific heat of Benzene Gas - C6H6 - at temperatures ranging 250 - 900 K.
Benzene Liquid - Thermal Properties
Properties like density, specific heat, thermal conductivity, dynamic viscosity and Prandtl number.
Butane - Thermophysical Properties
Chemical, physical and thermal properties of n-Butane.
Carbon Dioxide (CO₂) Properties & Characteristics: Density, Thermal Data & More
Carbon Monoxide - CO - Thermophysical Properties
Chemical, Physical and Thermal Properties of Carbon Monoxide - CO.
Conductive Heat Transfer
Ethanol - Thermophysical properties
Chemical, physical and thermal properties of ethanol (also called alcohol or ethyl alcohol). Phase diagram included.
Heat Capacity
Helium - Thermophysical Properties
Chemical, Physical and Thermal Properties of Helium - He.
Hydrocarbons - Physical Data
Hydrocarbons - Autoignition Temperatures and Flash Points
Autoignition temperatures and flash points (°C and °F) of different types of hydrocarbons with varying carbon numbers up to C12.
Chemical, Physical and Thermal Properties of Hydrogen - H2.
Hydrogen sulfide - Thermophysical Properties
Chemical, physical and thermal properties of hydrogen sulfide, H2S, also called hydrosulfuric acid, sewer gas and stink damp. Phase diagram included.
Individual & Universal Gas Constants: Definitions, Values, and Applications
Liquids - Latent Heat of Evaporation
Latent heat of vaporization for fluids like alcohol, ether, nitrogen, water and more.
Liquids - Vapor Pressures
Vapor and saturation pressure for some common liquids.
Methane (CH₄): Thermophysical Properties and Phase Diagram
Methanol - Thermophysical Properties
Chemical, physical and thermal properties of methanol, CH3OH (also called carbinol, wood alcohol, hydroxy methyl and methyl alcohol). Phase diagram included.
Pressure
Solubility
The amount of a solute that can be dissolved in a solvent.
Speed of Sound - Equations
Calculate the speed of sound (the sonic velocity) in gases, fluids or solids.
Standard State and Enthalpy of Formation, Gibbs Free Energy of Formation, Entropy and Heat Capacity
Definition and explanation of the terms standard state and standard enthalpy of formation, with listing of values for standard enthalpy and Gibbs free energy of formation, as well as standard entropy and molar heat capacity, of 370 inorganic compounds.
Substances Triple Points
Triple points for common substances.
Surface Tension
Surface tension of liquids like water, mercury, oils and more.
