Surface Tension
Surface tension is caused by the inward attraction of molecules at a boundary.
Surface tension is the energy required to stretch a unit change of surface area - and the surface tension will form a drop of liquid to a sphere since the sphere offers the smallest area for a definite volume.
Surface tension can be defined as
σ = Fs / l (1)
σ = surface tension (N/m)
Fs = stretching force (N)
l = unit length (m)
Alternative Units
Alternatively, surface tension is typically measured in dynes/cm, which is
- the force in dynes required to break a film of length 1 cm
or as surface energy J/m2 or alternatively ergs per square centimeter.
- 1 dynes/cm (dyn/cm) = 0.001 N/m = 0.0000685 lbf/ft = 0.571 10-5 lbf/in = 0.0022 poundal/ft = 0.00018 poundal/in = 1.0 mN/m = 0.001 J/m2 = 1.0 erg/cm2 = 0.00010197 kgf/m
Common Imperial units used are lb/ft and lb/in.
Surface Tension of Water
Surface tension of water at some temperatures:
Temperature (oC) | Surface Tension - σ - (N/m) |
0 | 0.0757 |
10 | 0.0742 |
20 | 0.0728 |
30 | 0.0712 |
40 | 0.0696 |
50 | 0.0679 |
60 | 0.0662 |
70 | 0.0644 |
80 | 0.0626 |
90 | 0.0608 |
100 | 0.0588 |
Surface Tension Common Fluids
Surface tension of fluids at 25oC (77oF).
Fluid | Surface Tension (N/m) |
Acetaldehyde | 0.021 |
Acetic acid, Ethanoic acid | 0.027 |
Acetic anhydride, Acetyl acetat | 0.032 |
Acetone, 2-Propanone | 0.024 |
Acetonitrile, Methyl cyanide | 0.287 |
Allyl alcohol | 0.025 |
Ammonia, R-717 | 0.021 |
Aniline, Benzenamine | 0.042 |
Anisole, Methoxybenzene | 0.035 |
Benzene, Annulene | 0.028 |
Benzonitrile, Phenyl cyanide | 0.039 |
Benzylamine | 0.039 |
Bromine | 0.041 |
Bromobenzene | 0.035 |
Bromoethane | 0.024 |
n-Butane | 0.023 |
1-Butanol, Butyl alcohol | 0.025 |
Butyl acetat | 0.025 |
Butylamine | 0.023 |
Diethyl ether | 0.017 |
Carbon dioxide | 0.00056 |
Carbon disulfide | 0.032 |
Carbon tetrachloride | 0.027 |
Clorobenzene, Phenyl chloride | 0.033 |
Chlorodifluoromethane, HCFC-22 | 0.008 |
Chloroform | 0.0271 |
1-Chlorohexane, Hexyl chloride | 0.026 |
1-Chloropentane | 0.024 |
p-Cresol | 0.035 |
Cyclohexane | 0.024 |
Cyclohexanol | 0.033 |
Cyclohexene | 0.026 |
Cyclopentane | 0.022 |
Decane | 0.024 |
Dibutylamine | 0.024 |
Dichlorodifluoromethane, CFC-12 | 0.0086 |
Diethylene glycol | 0.045 |
Diethyl ether, Ethyl ether | 0.017 |
Diethyl sulfide, Ethyl sulfide | 0.025 |
Ethane | 0.00048 |
Ethanol, Ethyl Alcohol, Pure Alcohol, Grain Alcohol, Drinking Alcohol | 0.022 |
Ethanolamine, glycinol | 0.048 |
Ethyl acetate | 0.024 |
Ethylamine, Ethanamine | 0.019 |
Ethylbenzene, Phenylethane | 0.029 |
Ethyl benzoate | 0.035 |
Ethyl bromide | 0.025 |
Ethyl mercaptan | 0.024 |
Ethylene glycol | 0.0477 |
Formamide | 0.057 |
Formixc acis, Methanoic acid | 0.037 |
Furfural | 0.043 |
n-Heptane | 0.020 |
Heptanoic acid, Enanthic acid | 0.028 |
Hexadekane, Cetane | 0.027 |
n-Hexane | 0.018 |
Hexanenitrile, Capronitrile | 0.027 |
1-Hexanol, Caproyl alcohol | 0.026 |
1-Hexene | 0.018 |
Hydrazine | 0.066 |
Glycerol | 0.064 |
Isobenzene, Phenyl iodide | 0.039 |
Isobutane, 2-Methylpropane | 0.010 |
Isobutyl acetat. 2-Methylpropyl acetat | 0.023 |
Isobutyric acid | 0.025 |
Isopropanol, 2-propanol, Isopropyl Alcohol, Rubbing Alcohol, Sec-propyl Alcohol, s-Propanol | 0.022 |
Mercury, Quicksilver | 0.485 |
Methanol, Methyl alcohol | 0.022 |
Methyl acetat | 0.025 |
Methyl formate | 0.025 |
Nitrobenzene (50oC) | 0.041 |
Nitromethane, Nitrocarbol | 0.036 |
Nonane | 0.022 |
Octane | 0.021 |
Pentane | 0.015 |
Pentyl acetat | 0.025 |
Propane, LPG | 0.007 |
1-Propanol, Propyl alcohol | 0.023 |
n-Propyl alcohol | 0.024 |
n-Propyl benzene | 0.030 |
Pyridine | 0.037 |
Trichloromethane, Chloroform | 0.023 |
Toluene, Methylbenzene | 0.028 |
Trifluormethane, Fluoroform | 0.00003 |
Undecane, Hendecane | 0.025 |
Water at 20oC | 0.072 |
Water, soapy at 20oC | 0.0250 - 0.0450 |
Water-d2, Heavy Water | 0.071 |
Xenon (10oC) | 0.00044 |
o-Xylene | 0.029 |
m-Xylene | 0.028 |
p-Xylene | 0.028 |
Surface Active Agents
Soaps, detergents or surfactants - also called surface-active agents - added to to water even in small substances decreases the surface tension of water to a considerable extent. Due to decreased surface tension water with soap can remove oil or grease where clean water can not.
Capillarity
Capillarity - or capillary action - is the ability of a narrow tube to draw a liquid upwards against the force of gravity.
Surface Tension - Water in contact with Air
Surface tension of water in contact with air for temperatures ranging 0 to 100 degC (32 to 212 degF) - in imperial units (BG units) and SI units.
Weber Number
The Weber Number may be useful when analyzing fluid flows where there is an interface between two different fluids.
