Weber Number
The Weber Number is a dimensionless value useful for analyzing fluid flows where there is an interface between two different fluids.
The Weber Number is the ratio between the inertial force and the surface tension force and the Weber number indicates whether the kinetic or the surface tension energy is dominant. It can be expressed as
We = ρ v2 l / σ                                              (1)
We = Weber number (dimensionless)
ρ = density of fluid (kg/m3, lb/ft3)
v = velocity of fluid (m/s, ft/s)
l = characteristic length (m, ft)
σ = surface tension (N/m)
Since the Weber Number represents an index of the inertial force to the surface tension force acting on a fluid element, it can be useful analyzing thin films flows and the formation of droplets and bubbles.
Fluid Mechanics
Dimensionless Numbers
Physical and chemical dimensionless quantities - Reynolds number, Euler, Nusselt, and Prandtl number - and many more.
Surface Tension
Surface tension of liquids like water, mercury, oils and more.
Surface Tension - Water in contact with Air
Surface tension of water in contact with air for temperatures ranging 0 to 100 degC (32 to 212 degF) - in imperial units (BG units) and SI units.
Technical Terms in Fluid Mechanics
Some commonly used technical terms in fluid mechanics.
