Benzene Gas - Specific Heat vs. Temperature
Specific heat of Benzene Gas - C6H6 - at temperatures ranging 250 - 900 K:
Benzene Gas - C6H6 - Specific Heat vs. Temperature
Temperature
- T -
(K)
Specific Heat
- cp -
(kJ/(kg K))
250 0.850
275 0.957
300 1.060
325 1.160
350 1.255
375 1.347
400 1.435
450 1.600
500 1.752
550 1.891
600 2.018
650 2.134
700 2.239
750 2.335
800 2.422
850 2.500
900 2.571
Material Properties
Online calculator, figures and table showing density and specific weight of benzene, C6H6, at temperatures ranging from 5 to 325 °C (42 to 620 °F) at atmospheric and higher pressure - Imperial and SI Units.
Benzene Liquid - Thermal Properties
Properties like density, specific heat, thermal conductivity, dynamic viscosity and Prandtl number.
Gases - Densities
