The output dynamic viscosity is given as Pa*s, N*s/m 2 , cP, mPa*s, lb f *s/ft 2 and lb m /(ft*h),
while the kinematic viscosity is given as cSt, m 2 /s, and ft 2 /s
See also other properties of Benzene at varying temperature and pressure: Density and specific weight , and Thermophysical properties at standard conditions , as well as dynamic and kinematic viscosity of air , ammonia , butane , carbon dioxide , ethane , ethanol , ethylene , methane , methanol , nitrogen , oxygen , propane and water .
Dynamic viscosity of benzene at gas-liquid equilibrium pressure:
Kinematic viscosity of benzene at gas-liquid equilibrium pressure:
Dynamic (absolute) and kinematic viscosity of benzene at given temperatures and pressures, SI and Imperial units:
For full table Dynamic and Kinematic Viscosity - rotate the screen!
State | Temperature | Pressure | Dynamic (Absolute) Viscosity | Kinematic viscosity | ||||||||
[K] | [°C] | [°F] | [bara] | [psia] | [μPa s] | [cP] | [lb f s/ft 2 *10 -6 ] | [lb m /ft s*10 -6 ] | [lb m /ft h] | [cSt], [m 2 /s*10 -6 ] | [ft 2 /s*10 -6 ] | |
Liquid at equilibrium | 278.70 | 5.55 | 41.99 | 0.0480 | 0.696 | 828.1 | 0.8281 | 17.30 | 556.5 | 2.003 | 0.9266 | 9.974 |
280 | 6.9 | 44.3 | 0.0515 | 0.747 | 810.4 | 0.8104 | 16.93 | 544.6 | 1.960 | 0.9082 | 9.775 | |
300 | 26.9 | 80.3 | 0.138 | 2.00 | 596.2 | 0.5962 | 12.45 | 400.6 | 1.442 | 0.6841 | 7.364 | |
320 | 46.9 | 116 | 0.321 | 4.65 | 452.5 | 0.4525 | 9.451 | 304.1 | 1.095 | 0.5324 | 5.730 | |
340 | 66.9 | 152 | 0.661 | 9.59 | 352.7 | 0.3527 | 7.366 | 237.0 | 0.8532 | 0.4258 | 4.583 | |
360 | 86.9 | 188 | 1.24 | 18.0 | 281.1 | 0.2811 | 5.871 | 188.9 | 0.6800 | 0.3488 | 3.755 | |
380 | 107 | 224 | 2.16 | 31.3 | 228.4 | 0.2284 | 4.770 | 153.5 | 0.5525 | 0.2918 | 3.141 | |
400 | 127 | 260 | 3.53 | 51.2 | 188.5 | 0.1885 | 3.937 | 126.7 | 0.4560 | 0.2485 | 2.674 | |
450 | 177 | 350 | 9.72 | 141 | 122.5 | 0.1225 | 2.558 | 82.32 | 0.2963 | 0.1768 | 1.904 | |
500 | 227 | 440 | 21.7 | 314 | 82.34 | 0.08234 | 1.720 | 55.33 | 0.1992 | 0.1349 | 1.452 | |
550 | 277 | 530 | 42.1 | 611 | 52.37 | 0.05237 | 1.094 | 35.19 | 0.1267 | 0.1124 | 1.210 | |
Gas at equilibrium | 278.7 | 5.6 | 42.0 | 0.0480 | 0.696 | 6.960 | 0.00696 | 0.1454 | 4.677 | 0.01684 | 42.88 | 461.6 |
280 | 6.9 | 44.3 | 0.051 | 0.747 | 6.994 | 0.006994 | 0.1461 | 4.700 | 0.01692 | 40.36 | 434.4 | |
300 | 26.9 | 80.3 | 0.138 | 2.00 | 7.509 | 0.007509 | 0.1568 | 5.046 | 0.01816 | 17.22 | 185.3 | |
320 | 46.9 | 116 | 0.321 | 4.65 | 8.031 | 0.008031 | 0.1677 | 5.397 | 0.01943 | 8.404 | 90.46 | |
340 | 66.9 | 152 | 0.661 | 9.59 | 8.564 | 0.008564 | 0.1789 | 5.755 | 0.02072 | 4.574 | 49.24 | |
360 | 86.9 | 188 | 1.24 | 18.0 | 9.113 | 0.009113 | 0.1903 | 6.124 | 0.02205 | 2.699 | 29.06 | |
380 | 107 | 224 | 2.16 | 31.3 | 9.685 | 0.009685 | 0.2023 | 6.508 | 0.02343 | 1.708 | 18.38 | |
400 | 127 | 260 | 3.53 | 51.2 | 10.3 | 0.0103 | 0.2151 | 6.921 | 0.02492 | 1.144 | 12.31 | |
450 | 177 | 350 | 9.72 | 141 | 12.22 | 0.01222 | 0.2552 | 8.211 | 0.02956 | 0.5029 | 5.413 | |
500 | 227 | 440 | 21.7 | 314 | 15.62 | 0.01562 | 0.3262 | 10.50 | 0.03779 | 0.2711 | 2.918 | |
550 | 277 | 530 | 42.1 | 611 | 25.18 | 0.02518 | 0.5259 | 16.92 | 0.06091 | 0.1675 | 1.803 | |
Liquid | 298 | 25 | 77 | 1 | 14.5 | 604 | 0.604 | 12.6 | 406 | 1.46 | 0.691 | 7.44 |
323 | 50 | 122 | 1 | 14.5 | 436 | 0.436 | 9.11 | 293 | 1.05 | 0.515 | 5.54 | |
348 | 75 | 167 | 1 | 14.5 | 335 | 0.335 | 7.00 | 225 | 0.810 | 0.409 | 4.40 |
Viscosity, Dynamic (Absolute)
centipoise [cP], gram/(centimeter second) [g/(cm s)] = poise [P], kilogram/meter second [kg/m s]=newton second/square meter [N s/m 2 ]= pascal second [Pa s], pound/(foot hour) [lb/(ft h)], pound/(foot second) [lb/(ft s)], reyn [reyn]
Viscosity, Kinematic
centistoke [cSt] = square millimeter/second [mm 2 /s], square foot/hour [ft 2 /h], square foot/second [ft 2 /s], square inch/second [in 2 /s], square meter/hour [m 2 /h], square meter/second [m 2 /s], stoke [St] = square centimeter/second [cm 2 /s]
Online calculator, figures and table showing density and specific weight of benzene, C6H6, at temperatures ranging from 5 to 325 °C (42 to 620 °F) at atmospheric and higher pressure - Imperial and SI Units.
Specific heat of Benzene Gas - C6H6 - at temperatures ranging 250 - 900 K.
Properties like density, specific heat, thermal conductivity, dynamic viscosity and Prandtl number.
Hydrodynamic losses through pumps depends on fluid viscosities.
Online calculator, figures and tables showing dynamic and kinematic viscosity of ethane, C2H6, at varying temperature and pressure - Imperial and SI Units
Absolute (dynamic) viscosity for common food products.
Dielectric constants or permittivities of some fluids or liquids.
Absolute (dynamic) viscosity values for some common fluids.
Latent heat of vaporization for fluids like alcohol, ether, nitrogen, water and more.
Specific gravities of liquids like alcohol, oils, benzene, water and many more.
Dynamic viscosities for motor oils SAE 10 to 50 for temperatures ranging 0-100 oC.
Online calculator, figures and tables showing dynamic and kinematic viscosity of nitrogen, N2, at varying temperature and pressure - Imperial and SI Units.
The attenuation in a room depends on the location of the sound source and the receiver - and the room constant.
Absolute viscosity of steam at pressure ranging 1 - 10000 psia.
