Sound - Attenuation and the Directivity Coefficient
For a continuing sound source the sound level in a room is the sum of direct and reverberant sound. The sound pressure for a receiver can be expressed as
Lp = LN + log(D / (4 π r2) + 4 / R) (1)
Lp = received sound pressure level (dB)
LN = sound power level from source (dB)
D = directivity coefficient
R = room constant (m2 Sabine)
π = 3.14 .....
r = distance from source (m)
Directivity coefficient - D
The figure below can be used to approximate the Directivity coefficient - D - for typical locations of the receiver and the sound source
(1) can be transformed to express the difference between the received sound pressure level and emitted sound power level - the attenuation - as:
Lp - LN = 10 log(D / (4 π r2) + 4 / R) (2)
Room Sound Attenuation Calculator
Room Sound Attenuation (Lp - LN) - (dB) :
The attenuation (Lp - LN) can also be estimated from the diagram below by modifying (2) to be expressed as the ratio between "distance r between source and receiver" and "square of the directivity coefficient D" - and the total room sound absorption in m2 Sabine.
Example - Sound Attenuation in a Room
For a room the acoustic property total room sound absorption is 1000 m2 Sabine. For a listener in the middle of the room with a directivity constant 1 and at distance 1 m from the sound source - the ratio
r / D1/2 = 1 / (1 m)1/2
= 1
From the diagram above the attenuation can estimated to approximately
10 dB
• Acoustics
• Noise and Attenuation
Mercury - Thermodynamic Properties
Properties of saturated liquid Mercury - Hg - density, specific heat capacity, kinematic viscosity, thermal conductivity and Prandtl number.
Propagation of Sound Indoors - the Room Constant
In a room the sound or noise will reach the receiver as direct and reverberant sound.
Sound - Abatement vs. the Distance from Source
The disruption of the sound pressure wave and the reduction of noise is called attenuation - Sound Pressure Level vs. distance calculator.
Sound - Attenuation and Speed vs. Sound Frequency and Air Humidity
The speed and attenuation of sound in moist air varies with sound frequency and air humidity.
Sound - Room Attenuation in Direct Sound Fields
Room size, absorption characteristics - and attenuation in direct sound fields.
Sound Attenuation - Duct split to Terminals
Estimating sound attenuation where ducts splits to terminals.
Sound Attenuation in Duct Elbows
Noise attenuation in duct elbows by reflected sound.
Sound Power
