Sound Attenuation - Duct split to Terminals
Splitting ducts to terminals will reduce the sound power level - LN - transferred to each terminal.
The sound power is reduced according reduced volume of air.
For equal terminals the attenuation to each terminal is indicated in the diagram below.
Example - Sound Attenuation from a Duct to Equal Terminals
According the diagram above - for a duct that splits into four equal terminals the sound attenuation from duct to each terminal is approximate
6 dB
Acoustics
Noise and Attenuation
Lined Sheet-Metal Ducts - Sound Attenuation
Noise attenuation in rectangular straight, lined, sheet metal ducts.
Sound - Attenuation and the Directivity Coefficient
The attenuation in a room depends on the location of the sound source and the receiver - and the room constant.
Sound Attenuation - Main Duct to Branch Ducts
Sound attenuation from main ducts to branch ducts.
Sound Attenuation in Duct Elbows
Noise attenuation in duct elbows by reflected sound.
Sound Attenuation in Ducts due to End Reflection
Low frequency noise transferred from main duct to end terminals is reflected back to main duct.
Sound Transmission through Duct Walls
Sound transmission from ducts to surrounding rooms.
Unlined Sheet-Metal Ducts - Sound Attenuation
Noise attenuation in unlined sheet-metal ducts.
