The sound attenuation in an unlined 500 mm duct elbow at 500 Hz is
8 dB
Room acoustics and acoustic properties, decibel A, B and C, Noise Rating (NR) curves, sound transmission, sound pressure, sound intensity and sound attenuation.
Noise attenuation in rectangular straight, lined, sheet metal ducts.
The speed and attenuation of sound in moist air varies with sound frequency and air humidity.
The attenuation in a room depends on the location of the sound source and the receiver - and the room constant.
Estimating sound attenuation where ducts splits to terminals.
Sound attenuation from main ducts to branch ducts.
Low frequency noise transferred from main duct to end terminals is reflected back to main duct.
Sound transmission from ducts to surrounding rooms.
Sound transmitted through duct walls, floors and ceilings.
Noise attenuation in unlined sheet-metal ducts.
