Lined Sheet-Metal Ducts - Sound Attenuation
Attenuation in ducts with 25 mm lining are indicated below:
Attenuation in ducts with 50 mm lining are indicated below:
Example - Sound Attenuation in Lined Duct
The sound attenuation in 610 x 610 mm lined duct is approximately 2.5 dB/m at frequency 250 Hz. The sound attenuation in 10 m duct can be calculated as
(10 m) (2.5 dB/m) = 25 dB
Acoustics
Noise and Attenuation
Sound - Attenuation and Speed vs. Sound Frequency and Air Humidity
The speed and attenuation of sound in moist air varies with sound frequency and air humidity.
Sound Attenuation - Duct split to Terminals
Estimating sound attenuation where ducts splits to terminals.
Sound Attenuation - Main Duct to Branch Ducts
Sound attenuation from main ducts to branch ducts.
Sound Attenuation in Duct Elbows
Noise attenuation in duct elbows by reflected sound.
Sound Transmission through Duct Walls
Sound transmission from ducts to surrounding rooms.
Unlined Sheet-Metal Ducts - Sound Attenuation
Noise attenuation in unlined sheet-metal ducts.
