Sound - Attenuation and Speed vs. Sound Frequency and Air Humidity
Attenuation and speed of sound in air varies with the frequency of the sound and the air humidity.
Attenuation
Download and print Air Humidity and Sound Attenuation Chart
Speed of Sound
Download and print Air Humidity and Speed of Sound Chart
Acoustics
Room acoustics and acoustic properties, decibel A, B and C, Noise Rating (NR) curves, sound transmission, sound pressure, sound intensity and sound attenuation.
Noise and Attenuation
Air - Speed of Sound vs. Temperature
Speed of sound in air at standard atmospheric pressure with temperatures ranging -40 to 1000 °C (-40 to 1500 °F) - Imperial and SI Units.
Gases - Speed of Sound
Speed of sound in some gases at zero degrees Celsius and atmospheric pressure.
Lined Sheet-Metal Ducts - Sound Attenuation
Noise attenuation in rectangular straight, lined, sheet metal ducts.
Liquids - Speed of Sound
Speed of sound in common fluids like water, glycerol, kerosene and more.
Noise Attenuation in Chambers
Chamber sound attenuation.
Propagation of Outdoor Sound - Partial Barriers
The transmission of outdoor sound through and around barriers - the Fresnel Number.
Propagation of Sound Outdoors - Attenuation vs. Distance
The propagation of outdoors sound vs. distance and attenuation.
Seawater - Attenuation of Sound
Attenuation of sound in seawater vs. temperature and frequency.
Solids and Metals - Speed of Sound
Speed of sound in solids and metals like aluminum, brass, concrete and more.
Sound - Attenuation and the Directivity Coefficient
The attenuation in a room depends on the location of the sound source and the receiver - and the room constant.
An introduction to the nature of sound with frequencies, wave-lengths and octaves.
Sound - Room Attenuation in Direct Sound Fields
Room size, absorption characteristics - and attenuation in direct sound fields.
Sound Attenuation - Main Duct to Branch Ducts
Sound attenuation from main ducts to branch ducts.
Sound Attenuation in Duct Elbows
Noise attenuation in duct elbows by reflected sound.
Sound Transmission through Flanking Paths
Sound transmitted through duct walls, floors and ceilings.
Sound Transmission through Massive Walls or Floors
Sound transmission and attenuation in building elements like massive concrete walls or floors.
Speed of Sound - Equations
Calculate the speed of sound (the sonic velocity) in gases, fluids or solids.
Speed of Sound vs. Elevation, Temperature and Air Pressure
Altitude and speed of sound, temperature and pressure.
Ventilation Systems - Acoustic Calculation Procedure
Acoustic noise calculation procedure HVAC systems.
Water - Speed of Sound vs. Temperature
Speed of sound in water at temperatures ranging 32 - 212°F (0 - 100°C) - Imperial and SI units.
