Propagation of Sound Outdoors - Attenuation vs. Distance
The energy in the propagation direction of the sound is inversely proportional to the increasing surface area the sound propagates through and can be expressed as
Lp = LN + 10 log((Q / 4 π) (1 / r12+ 1 / r22+ ...+1 / rn2) + 4 / R) (1)
or modified for a single source:
Lp = LN + 10 log(Q / (4 π r2) + 4 / R) (1b)
Lp = sound pressure level (dB)
LN = sound power level source in decibel (dB)
Q = directivity coefficient (1 uniform spherical, 2 uniform half spherical (single reflecting surface), 4 uniform radiation over 1/4 sphere (two reflecting surfaces, corner)
r = distance from source (m)
R = room constant (m2)
Single Sound Source - Spherical Propagation
With uniform spherical radiation (1) can be modified to express the sound pressure level from a single sound source as
Lp = LN + 10 log(1 / (4 π r2)
= LN - 10 log(4 π r2) (2)
since
Q = 1
R ≈ ∞
(2) can also be expressed as:
Lp = LN - 20 log(r) + K' (2b)
K' = -11 (single sound source and spherical radiation)
Single Sound Source - Hemi-Spherical Propagation
When the sound source propagates hemi-spherically with the source near ground, the constant can be set to
- K' = - 8
Note! When the distance - r - from a power source doubles, the sound pressure level decreases with 6 dB. This relationship is also known as the inverse square law.
Other factors that affects the radiation of the sound are the direction of the source, barriers between the source and the receiver and atmospheric conditions. Equation (1) can be modified to:
Lp = LN - 20 log(r) + K' + DI - Aa - Ab (3)
DI = directivity index
Aa = attenuation due to atmospheric conditions
Ab = attenuation due to barriers
Linear Sound Source
With a linear sound source, like a road or high-way with heavy traffic, (1) can be summarized (integrated) to express the sound pressure as
Lp = LN - 10 log(4 π r) (4)
Note! When the distance - r - from a linear power source doubles, the sound pressure level decreases with 3 dB.
• Acoustics
• Noise and Attenuation
Acoustic Impedance
Specific acoustic impedance is measure of the ability of a medium to transmit sound waves.
Noise generated by Road Traffic
Estimate noise level generated by traffic.
Outdoor Ambient Sound Pressure Levels
Outdoor ambient sound pressure levels (dBA) in rural and urban business and industrial environments with or without limited traffic.
Propagation of Outdoor Sound - Partial Barriers
The transmission of outdoor sound through and around barriers - the Fresnel Number.
Required Voice Level at Distance
Distance and perception of voice.
Sound - Abatement vs. the Distance from Source
The disruption of the sound pressure wave and the reduction of noise is called attenuation - Sound Pressure Level vs. distance calculator.
Sound - Attenuation and Speed vs. Sound Frequency and Air Humidity
The speed and attenuation of sound in moist air varies with sound frequency and air humidity.
Sound - Ldn - Day and Night Level
The EPA A-weighted sound level day and night equivalent definition - Ldn - for a 24 hour period.
