Required Voice Level at Distance
Talking with
  • a normal voice approximates to a sound pressure level of 70 dB
  • a raised voice approximates to a sound pressure level of 76 dB
  • a very loud voice approximates to a sound pressure level of 82 dB
  • a shouting voice approximates to a sound pressure level of 88 dB
at a distance of 1 ft (0.3 m).
For every doubling of the distance from the noise source the sound pressure level decrease with 6 decibels:
DistanceVoice Level (dB PSIL)
(ft)(m)NormalRaisedVery LoudShouting
1 0.3 70 76 82 88
3 0.9 60 66 72 78
6 1.8 54 60 66 72
12 3.7 48 54 60 66
24 7.3 42 48 54 60
PSIL - Preferred Speech Interference Level - is the arithmetic mean level in the 500 Hz, 1 kHz and 2 kHz octave bands. PSIL simulates the fact that sounds in the speech frequency range by humans are rendered indistinguishable from non-speech sources by excessive noise levels.
PSIL can be calculated as
PSIL = 1/3 (Lp500 + Lp1000 + Lp2000)                        (1)
PSIL = Preferred Speech Interference Level (dB)
Lpx = sound pressure at frequency x (dB)
dB calculated with reference pressure 2×10-5 Pa
If sound pressure is known in dBA - PSIL can be calculated as
PSIL = Lp (dBA) - 7
In social settings people often talk with normal voice levels at distances ranging 1 to 4 metre. In such cases background noise levels should not exceed 55 to 60 dBA.
In outdoor play and recreational areas people often communicate with raised or very loud voices at distances 5 to 10 metre and the background noise should not exceed 45 to 55 dBA.
Acoustics
Phonetic Alphabet
The phonetic alphabet used in international aircraft communications.
Propagation of Sound Outdoors - Attenuation vs. Distance
The propagation of outdoors sound vs. distance and attenuation.
Sound - Abatement vs. the Distance from Source
The disruption of the sound pressure wave and the reduction of noise is called attenuation - Sound Pressure Level vs. distance calculator.
Sound - Hearing Threshold vs. Age
Shift in hearing threshold for men and women vs. age.
Sound Propagation - the Inverse Square Law
Doubling of the distance from a noise source reduces the sound pressure level with 6 decibel.
