Sound - Hearing Threshold vs. Age
The hearing threshold is the minimum sound level a person’s ear is able to detect any sound. For adults - 0 dB is the reference level.
The hearing threshold is normally reduced with age as indicated below:
Men
Women
• Acoustics
Room acoustics and acoustic properties, decibel A, B and C, Noise Rating (NR) curves, sound transmission, sound pressure, sound intensity and sound attenuation.
• Physiology
Human physiology, air quality and comfort temperatures, activity and metabolic rates, health effects of carbon monoxide and more.
Decibel A, B and C
Noise - EPA Protective Levels
The noise level should not exceed certain values to protect public health and welfare.
Noise - Maximum Daily Dose Level
Maximum daily noise dose level when exposed to periods with different levels.
Noise Criterion vs. Noise Rating and dB(A)
Comparing Noise Criterion (NC, NCB, RNC) to Noise Rating (NR) and dB(A).
Noise Exposure - Permissible Levels and Duration
Exposure to noise should be controlled so that it is less than a maximum combination of exposure level and duration.
NR - the Noise Rating Curve
The Noise Rating (NR) Curve used to determine acceptable indoor environments for hearing preservation, speech communication and annoyance.
Required Voice Level at Distance
Distance and perception of voice.
An introduction to the nature of sound with frequencies, wave-lengths and octaves.
Sound Intensity
Acoustic power of sound per unit area.
Sound Pressure
