Outdoor Ambient Sound Pressure Levels
In residential areas most noise comes from transportation, construction, industrial, and human and animal sources. Road traffic noise is the major source of noise.
The noise can be highly variable. It is common that Day-Night sound levels - Ldn - in different areas may vary a range of 50 dB. The outdoor level - Ldn - in a wilderness areas may occur as low as 30-40 dBA compared to 85-90 dBA in a urban areas. Most urban dwellers lives in areas of Ldn more than  48 dBA
The table below indicates common outdoor sound pressure levels in rural and urban environments at the different octave bands.
Outdoor Sound Pressure (dB)
ConditionsOctave Band Center Frequency (Hz)
631252505001000200040008000
Night-time
Rural, no nearby traffic of concern 42 37 32 27 22 18 14 12
Suburban, no nearby traffic of concern 47 42 37 32 27 23 19 17
Urban, no nearby traffic of concern 52 47 42 37 32 28 24 22
Business or commercial area 57 52 47 42 37 33 29 27
Daytime
Business or commercial area 62 57 52 47 42 38 34 32
Industrial or manufacturing area 67 62 57 52 47 43 39 37
Within 300 ft (91 m) of continuous heavy traffic 72 67 62 57 52 48 44 42
Acoustics
Room acoustics and acoustic properties, decibel A, B and C, Noise Rating (NR) curves, sound transmission, sound pressure, sound intensity and sound attenuation.
Noise and Attenuation
Decibel
Logarithmic unit used to describe ratios of signal levels - like power or intensity - to a reference level.
Noise - Acceptable dBA Level
Noise generated by Road Traffic
Estimate noise level generated by traffic.
Propagation of Outdoor Sound - Partial Barriers
The transmission of outdoor sound through and around barriers - the Fresnel Number.
Propagation of Sound Outdoors - Attenuation vs. Distance
The propagation of outdoors sound vs. distance and attenuation.
SIL - the Speech Interference Levels
Background noise frequencies that interferes with speech.
Sound - Ldn - Day and Night Level
The EPA A-weighted sound level day and night equivalent definition - Ldn - for a 24 hour period.
Sound Power
