SIL - the Speech Interference Levels
Speech Interference Levels - SIL - are arithmetic average sound pressure levels at the 500, 1000 and 2000 Hz center frequencies - and a measure of the degree to which background noise interferes with speech.
  • 1 ft = 0.3048 m
The diagram above indicates the SIL and the distance at which a person would have talk in a normal, raised, very loud or shouting voice to be understood.
Example - Use of Voice with Background Noise
If the background noise - sound pressure level - is 75 dB and the distance between two persons is 6 m - they have to raise their voice to more than a very load level according the diagram above.
Acoustics
Decibel
Logarithmic unit used to describe ratios of signal levels - like power or intensity - to a reference level.
Noise - EPA Protective Levels
The noise level should not exceed certain values to protect public health and welfare.
Noise - Maximum Daily Dose Level
Maximum daily noise dose level when exposed to periods with different levels.
Noise Criterion vs. Noise Rating and dB(A)
Comparing Noise Criterion (NC, NCB, RNC) to Noise Rating (NR) and dB(A).
Outdoor Ambient Sound Pressure Levels
Outdoor ambient sound pressure levels (dBA) in rural and urban business and industrial environments with or without limited traffic.
Sound Level - Online Calculator
Calculate sound level, pressure and intensity.
Sound Power
Use of Telephones in Noisy Areas
Satisfactory, difficult and impossible noise levels for telephone use in noisy areas.
