Background noise interferes with telephone conversations, and
- conditions are satisfactory at levels less than 65 SIL (dB) (approx. 72 dBA)
- conditions are difficult at levels in the range 65 - 80 SIL (dB) (approx. 72 - 87 dBA)
- conditions are impossible at levels above 80 SIL (dB) (approx. 87 dBA)
SIL - Speech Interference Levels
Room acoustics and acoustic properties, decibel A, B and C, Noise Rating (NR) curves, sound transmission, sound pressure, sound intensity and sound attenuation.
Logarithmic unit used to describe ratios of signal levels - like power or intensity - to a reference level.
Comparing Noise Criterion (NC, NCB, RNC) to Noise Rating (NR) and dB(A).
Background noise frequencies that interferes with speech.
- the most efficient way to navigate the Engineering ToolBox!
About Engineering ToolBox!
