Sound - Ldn - Day and Night Level
The Environmental Protection Agency - EPA - has adopted a system of four "sound descriptors"
to summarize how sound is heard and measured and to determine the impact of noise on health and welfare.
Day-Night Sound Level - Ldn
is the A-weighted equivalent sound level for a 24 hour period with an additional 10 dB imposed on the equivalent sound levels for night time hours of 10 pm (22) to 7 am (07).
Day-Night Sound Level can be expressed as
Ldn = 10 log (1 / 24 (15 (10Ld/10) + 9 (10((Ln + 10)/10)))                            (1)
Ldn = day-night sound level (dBA)
Ld = daytime equivalent sound level (dBA)
Ln = nighttime equivalent sound level (dBA)
Examples of typical outdoor Day-Night Average Sound at various locations:
Typical Day and Night Sound Level vs. Location
LocationLdn (dBA)
Apartment next to freeway 87
3/4 mile from runway at major airport 86
Downtown with construction activity 79
Old urban residential area 59
Wooded residential 52
Agricultural crop land 44
Rural residential 39
Wilderness ambient 35
Example - Day-Night Sound Level
The equivalent daytime sound level is 70 dB and the equivalent nighttime sound level is 50 dB. The Day-Night sound level can be calculated as
Ldn = 10 log (1 / 24 (15 (10(70 dB)/10) + 9 (10((50 dB)+ 10)/10))
      = 68.2 dB
Day-Night Sound Level Calculator
Use the calculator below to calculate EPA 24 hour Day-Night sound level.
Acoustics
Room acoustics and acoustic properties, decibel A, B and C, Noise Rating (NR) curves, sound transmission, sound pressure, sound intensity and sound attenuation.
Noise - Acceptable dBA Level
Noise - EPA Protective Levels
The noise level should not exceed certain values to protect public health and welfare.
Outdoor Ambient Sound Pressure Levels
Outdoor ambient sound pressure levels (dBA) in rural and urban business and industrial environments with or without limited traffic.
Phonetic Alphabet
The phonetic alphabet used in international aircraft communications.
Propagation of Sound Outdoors - Attenuation vs. Distance
The propagation of outdoors sound vs. distance and attenuation.
Sound - Leq - Equivalent Level
The EPA Equivalent Sound Level - Leq - quantifies the noise environment to a single value of sound level for any desired duration.
Sound - Ls - Exposure Level
The EPA Sound Exposure Level - Ls - describes the noise from a variable source.
Sound Pressure Level - OSHA A-Weighted per Day
OSHA maximum A-weighted sound pressure levels allowed per day.
