Sound Pressure Level - OSHA A-Weighted per Day
Maximum A-weighted sound pressure levels allowed by the U.S. Occupational Safety and Health Administration - OSHA -  for periods in a working day:
Duration per Day
(hr)
Maximum Allowed Sound Pressure Level
(dBA)
8 90
6 92
4 95
3 97
2 100
1.5 102
1 105
0.5 110
less than 0.25 115
Download and print Maximum Allowable Sound Pressure Level per Day chart
Acoustics
Noise - Acceptable dBA Level
Noise - Recommended Exposure Limits (REL)
The NIOSH noise Recommended Exposure Limit - REL - for occupational noise
RC - the Room Criteria
The Room Criteria (RC) is used to measure background noise in buildings for frequencies ranging 16 to 4000 Hz.
Sound - Ldn - Day and Night Level
The EPA A-weighted sound level day and night equivalent definition - Ldn - for a 24 hour period.
Sound - Leq - Equivalent Level
The EPA Equivalent Sound Level - Leq - quantifies the noise environment to a single value of sound level for any desired duration.
Sound - Ls - Exposure Level
The EPA Sound Exposure Level - Ls - describes the noise from a variable source.
