Water - Speed of Sound vs. Temperature
Speed of Sound in Water - imperial units (BG units)
Temperature - t - (oF) | Speed of Sound - c - (ft/s) |
32 | 4603 |
40 | 4672 |
50 | 4748 |
60 | 4814 |
70 | 4871 |
80 | 4919 |
90 | 4960 |
100 | 4995 |
120 | 5049 |
140 | 5091 |
160 | 5101 |
180 | 5095 |
200 | 5089 |
212 | 5062 |
Speed of Sound in Water - in SI units
Temperature - t - (oC) | Speed of Sound - c - (m/s) | |
Water | Seawater | |
0 | 1403 | 1449 |
5 | 1427 | |
10 | 1447 | 1490 |
20 | 1481 | 1522 |
30 | 1507 | 1546 |
40 | 1526 | 1563 |
50 | 1541 | |
60 | 1552 | |
70 | 1555 | |
80 | 1555 | |
90 | 1550 | |
100 | 1543 |
- Seawater with salinity S = 35 (35.17 g/kg)
- 1 m/s = 3.28 ft/s
- Speed and Velocity of Sound - Speed of sound in air, fluids and solids. Formulas and values for different materials
Note that speed is a scalar quantity. Velocity is vector quantity with direction.
• Acoustics
Acoustic Impedance
Specific acoustic impedance is measure of the ability of a medium to transmit sound waves.
Air - Speed of Sound vs. Temperature
Speed of sound in air at standard atmospheric pressure with temperatures ranging -40 to 1000 °C (-40 to 1500 °F) - Imperial and SI Units.
Gases - Speed of Sound
Speed of sound in some gases at zero degrees Celsius and atmospheric pressure.
Liquids - Speed of Sound
Speed of sound in common fluids like water, glycerol, kerosene and more.
Solids and Metals - Speed of Sound
Speed of sound in solids and metals like aluminum, brass, concrete and more.
Sound - Attenuation and Speed vs. Sound Frequency and Air Humidity
The speed and attenuation of sound in moist air varies with sound frequency and air humidity.
An introduction to the nature of sound with frequencies, wave-lengths and octaves.
Speed of Sound - Equations
Calculate the speed of sound (the sonic velocity) in gases, fluids or solids.
Speed of Sound - Online Calculator
A free online speed of sound calculator.
Speed of Sound vs. Elevation, Temperature and Air Pressure
Altitude and speed of sound, temperature and pressure.
Velocity Units Converter
Convert between speed and velocity units like m/s, km/h, knots, mph and ft/s.
