Gases - Speed of Sound
The speed of sound depends on the density and the bulk modulus elasticity of a gas.
Speed of sound for some gases at 0 oC and atmospheric pressure:
Gas | Speed of Sound (m/s) |
Acetaldehyde | 278 |
Acetylene | 329 |
Air | 331 |
Air (20 oC) | 343 |
Ammonia (30 oC) | 440 |
Argon (27 oC) | 323 |
Benzene (90 oC) | 200 |
Bromine (58 oC) | 149 |
Carbon dioxide (51 oC) | 280 |
Carbon dioxide (0 oC) | 258 |
Carbon disulfide (35 oC) | 206 |
Carbon monoxide (0 oC) | 337 |
Carbon tetrachloride (22 oC) | 133 |
Chlorine (0 oC) | 205 |
Chloroform (22 oC) | 154 |
Cyclohexan (30 oC) | 181 |
Deuterium (0 oC) | 888 |
Diethyl ether (40 oC) | 187 |
Ethane (31 oC) | 316 |
Ethylene (20 oC) | 327 |
Fluorine (102 oC) | 332 |
Trichlorofluoromethane R11 (18 oC) | 143 |
1,1,2-trichloro-1,2,2-trifluoroethane R113 (53 oC) | 124 |
Dichlorodifluoromethane R12 (17 oC) | 140 |
Chlorodifluoromethane R22 (17 oC) | 179 |
Helium (0 oC) | 973 |
Hydrogen (27 oC) | 1320 |
Hydrogen bromide (0 oC) | 200 |
Hydrogen chloride (0 oC) | 294 |
Hydrogen iodide (0 oC) | 157 |
Hydrogen sulfide (24 oC) | 309 |
Hydrogen sulfide (0 oC) | 295 |
Krypton (30 oC) | 224 |
Methane (41 oC) | 466 |
Methane (27 oC) | 450 |
Neon (30 oC) | 461 |
Neon (0 oC) | 433 |
Nitric oxide (16 oC) | 334 |
Nitrogen (29 oC) | 354.4 |
Nitrous oxide (25 oC) | 268 |
Nitrous oxide (0 oC) | 256 |
Oxygen (27 oC) | 330 |
Oxygen (30 oC) | 332.2 |
Sulfur dioxide (0 oC) | 209 |
Sulfur hexafluoride (11 oC) | 133 |
Water vapor steam (100 oC) | 477.5 |
Water vapour steam 6 MPa (350 oC) | 571 |
Note that speed is a scalar quantity. Velocity is vector quantity with direction.
• Acoustics
Air - Speed of Sound vs. Temperature
Speed of sound in air at standard atmospheric pressure with temperatures ranging -40 to 1000 °C (-40 to 1500 °F) - Imperial and SI Units.
Carbon Dioxide (CO₂) Properties & Characteristics: Density, Thermal Data & More
Chemical, Physical and Thermal Properties of Hydrogen - H2.
Liquids - Speed of Sound
Speed of sound in common fluids like water, glycerol, kerosene and more.
Solids and Metals - Speed of Sound
Speed of sound in solids and metals like aluminum, brass, concrete and more.
Sound - Attenuation and Speed vs. Sound Frequency and Air Humidity
The speed and attenuation of sound in moist air varies with sound frequency and air humidity.
Speed of Sound - Equations
Calculate the speed of sound (the sonic velocity) in gases, fluids or solids.
Speed of Sound - Online Calculator
A free online speed of sound calculator.
Speed of Sound vs. Elevation, Temperature and Air Pressure
Altitude and speed of sound, temperature and pressure.
Water - Speed of Sound vs. Temperature
Speed of sound in water at temperatures ranging 32 - 212°F (0 - 100°C) - Imperial and SI units.
