Speed of Sound - Online Calculator
The speed of sound in air (or in other gases) can be expressed as
c = (k p / ρ)1/2
= (k R T)1/2 (1)
c = speed of sound (m/s, ft/s)
k = ratio of specific heats (adiabatic index, isentropic expansion factor)
p = pressure (Pa, psi)
R = 286.9 (J/kg K) = 1,716 (ft lb/slug oR) = individual gas constant specific for air
T = absolute temperature (K, R)
The calculators below can be used to estimate the speed of sound in air at temperatures close to 273.15 K (0 oC, 31 oF).
Speed of Sound - SI Units
Speed of Sound - Imperial Units
Example - Speed of Sound in Air
The individual gas constant for air is 286.9 J/kgK and the ratio of specific heat is 1.4. The speed of sound at 0 oC (273.15 K) can be calculated as
c = (1.4 (286.9 J/kgK) (273.15 K))1/2
= 331.2 m/s
• Acoustics
Air - Speed of Sound vs. Temperature
Speed of sound in air at standard atmospheric pressure with temperatures ranging -40 to 1000 °C (-40 to 1500 °F) - Imperial and SI Units.
Gases - Speed of Sound
Speed of sound in some gases at zero degrees Celsius and atmospheric pressure.
Liquids - Speed of Sound
Speed of sound in common fluids like water, glycerol, kerosene and more.
Mach Number
An introduction to the Mach Number.
Solids and Metals - Speed of Sound
Speed of sound in solids and metals like aluminum, brass, concrete and more.
Sound - Doppler Effect
The doppler effect is the change in sound frequency due to the relative motion between a source and a listener.
Speed of Sound vs. Elevation, Temperature and Air Pressure
Altitude and speed of sound, temperature and pressure.
Water - Speed of Sound vs. Temperature
Speed of sound in water at temperatures ranging 32 - 212°F (0 - 100°C) - Imperial and SI units.
