Liquids - Speed of Sound
The speed of sound in some common liquids are indicated in the table below.
Speed of sound in air at standard conditions is 343 m/s.
LiquidSpeed of Sound1)
(m/s)
Acetic acid (19.6 oC) 1173
Acetone (25 oC) 1170
Alcohol, ethyl (ethanol) (25 oC) 1144
Alcohol, methyl (25 oC) 1103
Alcohol, propyl 1205
Aniline (25 oC) 1640
Argon (-243 oC) 840
Benzene (25 oC) 1298
Bromobenzene (20 oC) 1169
Bismuth (280 oC) 1651
Butane (-0.5 oC) 1038
1-Butanol (20 oC) 1262
Caesium (40 oC) 980
Carbon bisulfide 1160
Carbon disulfide (25 oC) 1242
Carbon tetrachloride (Tetrachloromethane) (25 oC) 930
Castor oil 1474
Chloroform (25 oC) 984
Chlorobenzene (25 oC) 1270
Cyclohexane (20 oC) 1280
Cyclohexanol (25 oC) 1465
1-Decene (20 oC) 1250
Diethyl-ether (25 oC) 951
Ethane (-88.6 oC) 1316
Ethanol (20 oC) 1159
Ether 985
Ethylene (-103.8 oC) 1307
Ethylene glycol (25 oC) 1660
Fluorbenzene (20 oC) 1183
Glycerine 1920
Glycerol (glycerine) (25 oC) 1920
Helium (-269 oC) 180
Heptane 1138
Hexane 1203
n-Hexanol (25 oC) 1303
Hydrogen (-255 oC) 1246
Indium (160 oC) 2313
Iodobenzne (20 oC) 1114
Kerosene 1324
Lead (340 oC) 1766
Mercury (25 oC) 1450
Methane (-170 oC) 1420
Methanol (20 oC) 1116
Napthalene (100 oC) 1248
Neon (-243 oC) 540
Nitrobenzene (25 oC) 1463
Nitrogen (-195.8 oC) 851
Octane 1171
Oil (castor) (25 oC) 1490
Oil (lubricating) (25 oC) 1461
Oxygen (-202 oC) 1056
Pentane (20 oC) 1036
Petroleum 1330
Potassium (80 oC) 1869
n-Pentanol (25 oC) 1277
Phenol 1274
Propane (-42.1 oC) 1161
n-Propanol (25 oC) 1207
Pyridine (25 oC) 1417
Rubidium (50 oC) 1247
Sodium (110 oC) 2520
Tin (240 oC) 2471
Toluene (25 oC) 1306
Turpentine 1240
Water 1493
Water, 0 oC 1402
Water, 20 oC 1482
Water, sea with 3.5% salinity 1533
Water, sea with 3.5% salinity, 20 oC 1522
Zinc (450 oC) 2780
1) Based on temperature 25 oC
  • 1 m/s = 3.6 km/h = 196.85 ft/min = 3.28 ft/s = 2.237 mph
Note that speed is a scalar quantity. Velocity is vector quantity with direction.
Speed of Sound in Seawater
Temperature
(°C)
0 5 10 15 20 25 30
Speed of Sound
(m/s)
1449 1471 1490 1507 1522 1534 1546
Acoustics
Acoustic Impedance
Specific acoustic impedance is measure of the ability of a medium to transmit sound waves.
Air - Speed of Sound vs. Temperature
Speed of sound in air at standard atmospheric pressure with temperatures ranging -40 to 1000 °C (-40 to 1500 °F) - Imperial and SI Units.
Gases - Speed of Sound
Speed of sound in some gases at zero degrees Celsius and atmospheric pressure.
Seawater - Attenuation of Sound
Attenuation of sound in seawater vs. temperature and frequency.
Solids and Metals - Speed of Sound
Speed of sound in solids and metals like aluminum, brass, concrete and more.
Sound - Attenuation and Speed vs. Sound Frequency and Air Humidity
The speed and attenuation of sound in moist air varies with sound frequency and air humidity.
Speed of Sound - Equations
Calculate the speed of sound (the sonic velocity) in gases, fluids or solids.
Speed of Sound - Online Calculator
A free online speed of sound calculator.
Water - Speed of Sound vs. Temperature
Speed of sound in water at temperatures ranging 32 - 212°F (0 - 100°C) - Imperial and SI units.
