Individual & Universal Gas Constants: Definitions, Values, and Applications
The Universal and Individual Gas Constants are known from the Ideal Gas Law.
The Individual Gas Constant - R
The Individual Gas Constant depends on the particular gas and is related to the molecular weight of the gas. The value is independent of temperature. The induvidual gas constant, R, for a gas can be calculated from the universal gas constant, Ru ( given in several units below), and the gas molecular weight, Mgas :
R = Ru / Mgas (1)
In the imperial system the most common units for the individual gas constant are ft lb/slugoR. In the SI system the most common units are J/kg K.
Unit conversion: 1 J/kg K = 5.97994 ft lb/slug °R, and 1 ft lb/slug °R = 0.167226 J/kg K.
The Individual Gas Constant for gases:
| Gas | Molecular Weight | Individual Gas Constant - R | |||||||
| Name | Formula | (g/mol), (kg/kmol) | (J/kg K) | (kJ/kg K) | (Wh/(kg K)) | (kcal/(kg K)), (Btu(IT)/lb °F) | (kcal/(lb °F)) | (ft lbf/lb °R) | (ft lbf/slug °R) |
| Acetylene | C2H2 | 26.038 | 319.32 | 0.3193 | 0.08870 | 0.07627 | 0.0623 | 59.350 | 1910 |
| Air | A mixture | 28.9647 | 287.05 | 0.2871 | 0.07974 | 0.06856 | 0.0560 | 53.353 | 1717 |
| Ammonia | NH3 | 17.031 | 488.21 | 0.4882 | 0.13561 | 0.11661 | 0.0952 | 90.740 | 2919 |
| Argon | Ar | 39.948 | 208.13 | 0.2081 | 0.05781 | 0.04971 | 0.0406 | 38.684 | 1245 |
| Butane | C4 H10 | 58.122 | 143.05 | 0.1431 | 0.03974 | 0.03417 | 0.0279 | 26.588 | 855 |
| Butene | C4 H8 | 56.106 | 148.19 | 0.1482 | 0.04116 | 0.03539 | 0.0289 | 27.543 | 886 |
| Carbon Dioxide | CO2 | 44.010 | 188.92 | 0.1889 | 0.05248 | 0.04512 | 0.0368 | 35.114 | 1130 |
| Carbon Monoxide | CO | 28.010 | 296.84 | 0.2968 | 0.08246 | 0.07090 | 0.0579 | 55.171 | 1775 |
| Carbonic acid | H2CO3 | 62.025 | 134.05 | 0.1341 | 0.03724 | 0.03202 | 0.0261 | 24.915 | 802 |
| Chlorine | Cl2 | 70.906 | 117.26 | 0.1173 | 0.03257 | 0.02801 | 0.0229 | 21.794 | 701 |
| Chloromethane | CH3Cl | 50.488 | 164.68 | 0.1647 | 0.04575 | 0.03933 | 0.0321 | 30.608 | 985 |
| Dichlorofluorumethane | CHCl2F | 102.923 | 80.78 | 0.0808 | 0.02244 | 0.01929 | 0.0158 | 15.015 | 483 |
| Ethane | C2H6 | 30.069 | 276.51 | 0.2765 | 0.07681 | 0.06604 | 0.0539 | 51.393 | 1654 |
| Ethene | C2H4 | 28.053 | 296.38 | 0.2964 | 0.08233 | 0.07079 | 0.0578 | 55.086 | 1772 |
| Fluorine | F2 | 37.997 | 218.82 | 0.2188 | 0.06078 | 0.05226 | 0.0427 | 40.670 | 1309 |
| Helium | He | 4.003 | 2077.1 | 2.0771 | 0.57696 | 0.49610 | 0.4050 | 386.047 | 12421 |
| Hydrogen | H2 | 2.016 | 4124.2 | 4.1242 | 1.14563 | 0.98506 | 0.8043 | 766.541 | 24663 |
| Hydrogen bromide | HBr | 80.912 | 102.76 | 0.1028 | 0.02854 | 0.02454 | 0.0200 | 19.099 | 614 |
| Hydrogen chloride | HCl | 36.461 | 228.04 | 0.2280 | 0.06334 | 0.05447 | 0.0445 | 42.384 | 1364 |
| Hydrogen sulfide | H2S | 34.081 | 243.96 | 0.2440 | 0.06777 | 0.05827 | 0.0476 | 45.344 | 1459 |
| Krypton | Kr | 83.798 | 99.22 | 0.0992 | 0.02756 | 0.02370 | 0.0193 | 18.441 | 593 |
| Methane (natural gas) | CH4 | 16.042 | 518.28 | 0.5183 | 0.14397 | 0.12379 | 0.1011 | 96.329 | 3099 |
| Neon | Ne | 20.180 | 412.02 | 0.4120 | 0.11445 | 0.09841 | 0.0803 | 76.579 | 2464 |
| Nitrogen | N2 | 28.013 | 296.80 | 0.2968 | 0.08245 | 0.07089 | 0.0579 | 55.165 | 1775 |
| Nitrogen dioxide | NO2 | 46.006 | 180.73 | 0.1807 | 0.05020 | 0.04317 | 0.0352 | 33.590 | 1081 |
| Nitrogen trifluoride | NF3 | 71.002 | 117.10 | 0.1171 | 0.03253 | 0.02797 | 0.0228 | 21.765 | 700 |
| Nitrous oxide | N2O | 44.012 | 188.91 | 0.1889 | 0.05248 | 0.04512 | 0.0368 | 35.112 | 1130 |
| Oxygen | O2 | 31.999 | 259.84 | 0.2598 | 0.07218 | 0.06206 | 0.0507 | 48.294 | 1554 |
| Propane | C3 H8 | 44.096 | 188.56 | 0.1886 | 0.05238 | 0.04504 | 0.0368 | 35.045 | 1128 |
| Propene | C3 H6 | 42.080 | 197.59 | 0.1976 | 0.05489 | 0.04719 | 0.0385 | 36.724 | 1182 |
| Sulfur dioxide | SO2 | 64.064 | 129.78 | 0.1298 | 0.03605 | 0.03100 | 0.0253 | 24.122 | 776 |
| Sulfur hexafluoride | SF6 | 146.055 | 56.93 | 0.0569 | 0.01581 | 0.01360 | 0.0111 | 10.581 | 340 |
| Sulfur trioxide | SO3 | 80.063 | 103.85 | 0.1038 | 0.02885 | 0.02480 | 0.0203 | 19.302 | 621 |
| Water vapor | H2O | 18.015 | 461.52 | 0.4615 | 0.12820 | 0.11023 | 0.0900 | 85.780 | 2760 |
| Xenon | Xe | 131.293 | 63.33 | 0.0633 | 0.01759 | 0.01513 | 0.0123 | 11.770 | 379 |
The Universal Gas Constant - Ru
The Universal Gas Constant - Ru - appears in the ideal gas law and can be expressed as the product between the Individual Gas Constant - R - for the particular gas - and the Molecular Weight - Mgas - for the gas, and is the same for all ideal or perfect gases :
Ru = Mgas R (2)
The Universal Constant defined in Terms of the Boltzmann's Constant
The universal gas constant can be defined in terms of Boltzmann's constant k as:
Ru = k NA (3)
k = Boltzmann's constant = 1.381×10-23 (J/K)
NA = Avogadro Number = 6.022×1023 (1/mol)
The Molecular weight of a Gas Mixture
The average molecular weight of a gas mixture is equal to the sum of the mole fractions of each gas multiplied by the molecular weight of that particular gas:
Mmixture = Σ(xi Mi)
= (x1 M1 + ......+ xn Mn ) (4)
xi = mole fractions of each gas
Mi = the molar mass of each gas
The Universal Gas Constant - Ru - in alternative Units
- atm.cm3/(mol.K) : 82.057338
- atm.ft3/(lbmol.K) : 1.31443
- atm.ft3/(lbmol. oR) : 0.73024
- atm.l/(mol.K) : 0.0820 57338
- bar.cm3/(mol.K) : 83.144598
- bar.l/(mol.K) : 0.083144 598
- Btu/(lbmol.oR) : 1.9872036
- cal/(mol.K) : 1.9872
- erg/(mol.K) : 83144 598
- hp.h/(lbmol.oR) : 0.0007805
- inHg.ft3/(lbmol.oR) : 21.85
- J/(mol.K) : 8.3144598
- kJ/(kmol.K) : 8.3144598
- J/(kmol.K) : 8314.472
- (kgf/cm2).l/(mol.K) : 0.084784
- kPa.cm3/(mol.K) : 8314.4 598
- kWh/(lbmol.oR) : 0.000582
- lbf.ft/(lbmol. oR) : 1545.349
- mmHg.ft3/(lbmol.K) : 999
- mmHg.ft3/(lbmol. oR) : 555
- mmHg.l/(mol.K) : 62.363577
- Pa.m3/(mol.K) : 8.3144 598
- psf.ft3/(lbmol. oR) : 1545.3465
- psi.ft3/(lbmol. oR) : 10.73
- Torr.cm3/(mol.K) : 62364
See also:
- More material properties
- The Ideal Gas Law - Gases are highly compressible with changes in density directly related to changes in temperature and pressure.
- A Mixture of Gases - Properties of mixtures of gases.
- More about temperature
• Air Psychrometrics
• Gases and Compressed Air
Dry Air Thermodynamic and Physical Properties – Density, Specific Heat, Viscosity
THe essential thermodynamic properties of dry air like specific heat, ratio of specific heats, dynamic viscosity, thermal conductivity, Prandtl number, density and kinematic viscosity at temperatures ranging 175 - 1900 K.
Gas Mixtures - Properties
Gas mixtures and the ideal gas law, mass calculations, the individual gas constant and density.
Gases - Dynamic Viscosities
Absolute (dynamic) viscosities of some common gases.
Gases - Molar Specific Heats
Molar specific heats for some common gases at constant volume.
Humid Air and the Ideal Gas Law
Pressure, temperature and volume in a perfect ideal gas like moist air (air with water vapor).
Moist Air - Mole Fraction of Water Vapor
Mole fraction of water vapor is the ratio of water molecules to air and water molecules.
Nitrogen - Enthalpy, Internal Energy and Entropy vs. Temperature
Enthalpy, internal energy and entropy of Nitrogen as an ideal gas.
Rankine Efficiency
The efficiency of the Rankine cycle.
Sulfur Dioxide Liquid - Thermal Properties
Density, specific heat, thermal conductivity and more.
The Ideal Gas Law
Thermodynamic Terms - Functions and Relations
Water-Steam Mollier Diagram
