Sulfur Dioxide Liquid - Thermal Properties
Thermal properties of Sulfur Dioxide SO2
Temperature
- t -
(oC)
Density
- ρ -
(kg/m3)
Specific Heat
- cp -
(kJ/kg K)
Thermal Coductivity
- λ -
(W/m K)
Dynamic Viscosity
10-6
- η -
(Pa s)
Prandtl's no.
0 1435 1.33 0.212 367 2.31
20 1383 1.37 0.199 304 2.09
50 1296 1.48 0.177 234 1.96
  • 1 kg/m3 = 0.0624 lb/ft3
  • 1 kJ/(kg K) = 0.2389 kcal/(kg oC) = 0.2389 Btu/(lbm oF)
  • 1 W/(m K) = 0.5779 Btu/(ft h oF)
  • 1 Pa s (N s/m2) = 10 P (Poise) = 103 cP = 0.1020 kp s/m2 = 0.6721 lb/(ft s)
Material Properties
Gases - Densities
Gases - Dynamic Viscosities
Absolute (dynamic) viscosities of some common gases.
Gases - Specific Heats and Individual Gas Constants
Universal and Individual Gas Constants
