Gases - Specific Heats and Individual Gas Constants
The specific heat (= specific heat capacity) at constant pressure and constant volume processes, and the ratio of specific heats and individual gas constants - R - for some commonly used "ideal gases", are in the table below (approximate values at 68oF (20oC) and 14.7 psia (1 atm)).
For conversion of units, use the Specific heat online unit converter.
See also tabulated values of specific heat capacity of food and foodstuff, metals and semimetals, common liquids and fluids, common solids and other common substances as well as values of molar heat capacity of common organic substances and inorganic substances.
Gas or Vapor | Formula | Specific Heat | Specific Heat Ratio | Individual Gas constant - R - | ||||
cp (kJ/(kg K)) | cv (kJ/(kg K)) | cp (Btu/(lbmoF)) | cv (Btu/(lbmoF)) | κ = cp / cv | cp - cv (kJ/(kg K)) | cp - cv (ft lbf/(lbmoR)) | ||
Acetone | (CH3)2CO | 1.47 | 1.32 | 0.35 | 0.32 | 1.11 | 0.15 | |
Acetylene | C2H2 | 1.69 | 1.37 | 0.35 | 0.27 | 1.232 | 0.319 | 59.34 |
Air | 1.01 | 0.718 | 0.24 | 0.17 | 1.40 | 0.287 | 53.34 | |
Alcohol (ethanol) | C2H5OH | 1.88 | 1.67 | 0.45 | 0.4 | 1.13 | 0.22 | |
Alcohol (methanol) | CH3OH | 1.93 | 1.53 | 0.46 | 0.37 | 1.26 | 0.39 | |
Ammonia | NH3 | 2.19 | 1.66 | 0.52 | 0.4 | 1.31 | 0.53 | 96.5 |
Argon | Ar | 0.520 | 0.312 | 0.12 | 0.07 | 1.667 | 0.208 | |
Benzene | C6H6 | 1.09 | 0.99 | 0.26 | 0.24 | 1.12 | 0.1 | |
Blast furnace gas | 1.03 | 0.73 | 0.25 | 0.17 | 1.41 | 0.3 | 55.05 | |
Bromine | Br2 | 0.25 | 0.2 | 0.06 | 0.05 | 1.28 | 0.05 | |
Butane | C4H10 | 1.67 | 1.53 | 0.395 | 0.356 | 1.094 | 0.143 | 26.5 |
Carbon dioxide | CO2 | 0.844 | 0.655 | 0.21 | 0.16 | 1.289 | 0.189 | 38.86 |
Carbon monoxide | CO | 1.02 | 0.72 | 0.24 | 0.17 | 1.40 | 0.297 | 55.14 |
Carbon disulphide | CS2 | 0.67 | 0.55 | 0.16 | 0.13 | 1.21 | 0.12 | |
Chlorine | Cl2 | 0.48 | 0.36 | 0.12 | 0.09 | 1.34 | 0.12 | |
Chloroform | CHCl3 | 0.63 | 0.55 | 0.15 | 0.13 | 1.15 | 0.08 | |
Coal gas | 2.14 | 1.59 | ||||||
Combustion products | 1 | 0.24 | ||||||
Ethane | C2H6 | 1.75 | 1.48 | 0.39 | 0.32 | 1.187 | 0.276 | 51.5 |
Ether (diethyl ether) | (C2H5)2O | 2.01 | 1.95 | 0.48 | 0.47 | 1.03 | 0.06 | |
Ethylene | C2H4 | 1.53 | 1.23 | 0.4 | 0.33 | 1.240 | 0.296 | 55.08 |
Chlorodifluoromethane, R-22 | CHClF2 | 1.18 | ||||||
Helium | He | 5.19 | 3.12 | 1.25 | 0.75 | 1.667 | 2.08 | 386.3 |
Hexane | C6H14 | 1.06 | ||||||
Hydrochloric acid | 0.795 | 0.567 | ||||||
Hydrogen | H2 | 14.32 | 10.16 | 3.42 | 2.43 | 1.405 | 4.12 | 765.9 |
Hydrogen Chloride | HCl | 0.8 | 0.57 | 0.191 | 0.135 | 1.41 | 0.23 | 42.4 |
Hydrogen Sulfide | H2S | 0.243 | 0.187 | 1.32 | 45.2 | |||
Hydroxyl | OH | 1.76 | 1.27 | 1.384 | 0.489 | |||
Krypton | Kr | 0.25 | 0.151 | |||||
Methane | CH4 | 2.22 | 1.70 | 0.59 | 0.45 | 1.304 | 0.518 | 96.4 |
Methyl Chloride | CH3Cl | 0.240 | 0.200 | 1.20 | 30.6 | |||
Natural Gas | 2.34 | 1.85 | 0.56 | 0.44 | 1.27 | 0.5 | 79.1 | |
Neon | Ne | 1.03 | 0.618 | 1.667 | 0.412 | |||
Nitric Oxide | NO | 0.995 | 0.718 | 0.23 | 0.17 | 1.386 | 0.277 | |
Nitrogen | N2 | 1.04 | 0.743 | 0.25 | 0.18 | 1.400 | 0.297 | 54.99 |
Nitrogen tetroxide | N2O4 | 4.69 | 4.6 | 1.12 | 1.1 | 1.02 | 0.09 | |
Nitrous oxide | N2O | 0.88 | 0.69 | 0.21 | 0.17 | 1.27 | 0.18 | 35.1 |
Oxygen | O2 | 0.919 | 0.659 | 0.22 | 0.16 | 1.395 | 0.260 | 48.24 |
Pentane | C5H12 | 1.07 | ||||||
Propane | C3H8 | 1.67 | 1.48 | 0.39 | 0.34 | 1.13 | 0.189 | 35.0 |
Propene (propylene) | C3H6 | 1.5 | 1.31 | 0.36 | 0.31 | 1.15 | 0.18 | 36.8 |
Water Vapor Steam 1 psia. 120 – 600 oF |
H2O | 1.93 | 1.46 | 0.46 | 0.35 | 1.32 | 0.462 | |
Steam 14.7 psia. 220 – 600 oF | H2O | 1.97 | 1.5 | 0.47 | 0.36 | 1.31 | 0.46 | |
Steam 150 psia. 360 – 600 oF | H2O | 2.26 | 1.76 | 0.54 | 0.42 | 1.28 | 0.5 | |
Sulfur dioxide (Sulphur dioxide) | SO2 | 0.64 | 0.51 | 0.15 | 0.12 | 1.29 | 0.13 | 24.1 |
Xenon | Xe | 0.16 | 0.097 |
- κ = cp / cv - the specific heat capacity ratio
- cp = specific heat in a constant pressure process
- cv = specific heat in a constant volume process
- R- Individual Gas constant
See also tabulated values of specific heat of food and foodstuff, metals and semimetals, common liquids and fluids, Common solids and other common substances as well as values of molar heat capacity of common organic substances and inorganic substances.
• Thermodynamics
Air - Specific Heat Ratio
Specific Heat Ratio of air at temperatures ranging -40 - 1000 degC (-40 - 1500 degF) at standard atmospheric pressure - Imperial and SI Units.
Air - Specific Heat vs. Temperature at Constant Pressure
Online calculator with figures and tables showing specific heat (Cp and Cv) of dry air vs. temperature and pressure. SI and imperial units.
Argon - Thermophysical Properties
Chemical, Physical and Thermal Properties of Argon.
Compression and Expansion of Gases
Isothermal and isentropic gas compression and expansion processes.
Gases - Dynamic Viscosities
Absolute (dynamic) viscosities of some common gases.
Gases - Molar Specific Heats
Molar specific heats for some common gases at constant volume.
Heat Capacity
Heat, Work and Energy
Heat vs. work vs. energy.
Liquids and Fluids - Specific Heats
Nitrogen Gas - Specific Heat vs. Temperature
Specific heat of Nitrogen Gas - N2 - at temperatures ranging 175 - 6000 K
Solids - Specific Heats
Sulfur Dioxide Liquid - Thermal Properties
Density, specific heat, thermal conductivity and more.
The Ideal Gas Law
