Gases - Molar Specific Heats
Approximate molar specific heats at constant volume at room temperature for some common gases:
Gas | Specific Heat - Cv - (kcal/kmole K) |
Argon (Ar) | 3.0 |
Carbon monoxide (CO) | 5.02 |
Chlorine (Cl2) | 6.01 |
Ethane (C2H6) | 10.3 |
Ether ((C2H5)2O) | 30.8 |
Helium (He) | 3.02 |
Hydrogen (H2) | 4.88 |
Mercury vapor (Hg) | 3.0 |
Nitrogen (N2) | 6.97 |
Oxygen (O2) | 4.99 |
Sulfur dioxide (SO2) | 7.5 |
- 1 kcal = 4186.8 J = 426.9 kp m = 1.163×10-3 kWh = 3.088 ft lbf = 3.9683 Btu = 1000 cal
Density of Gases
Gases - Specific Heat and Individual Gas Constants
Individual & Universal Gas Constants: Definitions, Values, and Applications
Moist Air - Mole Fraction of Water Vapor
Mole fraction of water vapor is the ratio of water molecules to air and water molecules.
Mole and the Avagadro's Number
The mole is the SI base unit for an amount of a substance.
