The molecular weight (or molar mass) of a substance is the mass of one mole of the substance, and can be calculated by summarizing the molar masses of all the atoms in the molecule.
Components in Dry Air
Air is a mixture of several gases, where the two most dominant components in dry air are 21 vol% oxygen and 78 vol% nitrogen . Oxygen has a molar mass of 15.9994 g/mol and nitrogen has a molar mass of 14.0067 g/mol. Since both of these elements are diatomic in air - O2 and N2, the molar mass of oxygen gas is aprox. 32 g/mol and the molar mass of nitrogen gas is aprox. 28 g/mol.
The average molar mass is equal to the sum of the mole fractions of each gas multiplied by the molar mass of that particular gas:
Mmixture = x1 M1 + ......+ xn Mn (1)
xi = mole fractions of each gas
Mi = the molar mass of each gas
The molar mass of dry air with oxygen, nitrogen and the other components as indicated below is 28.9647 g/mol. Composition and content of each gas in air is given in the figures and the table below.
See also Air Density at varying pressure, Density and specific weight at varying temperature, Diffusion Coefficients for Gases in Air, Dynamic (absolute) and kinematic viscosity, Prandtl Number, Specific heat at varying temperature and Specific heat at varying pressure, Thermal Conductivity, Thermal Diffusivity, Properties at gas-liquid equilibrium conditions and Air properties, for other properties of air.
For full table with Molar mass an Molar mass in Air - rotate the screen!
| Components in dry air | Volume ratio = Molar ratio, compared to dry air | Molar Mass | Molar mass in air | |||
| Name | Formula | (mol/molair) | (vol %) | (g/mol) (kg/kmol) | (g/molair) (kg/kmolair) | (wt %) |
| Nitrogen | N2 | 0.78084 | 78.084 | 28.013 | 21.873983 | 75.52 |
| Oxygen | O2 | 0.20946 | 20.946 | 31.999 | 6.702469 | 23.14 |
| Argon | Ar | 0.00934 | 0.934 | 39.948 | 0.373114 | 1.29 |
| Carbon dioxide | CO2 | 0.00033 | 0.033 | 44.010 | 0.014677 | 0.051 |
| Neon | Ne | 0.00001818 | 0.001818 | 20.180 | 0.000367 | 0.0013 |
| Helium | He | 0.00000524 | 0.000524 | 4.003 | 0.000021 | 0.00007 |
| Methane | CH4 | 0.00000179 | 0.000179 | 16.042 | 0.000029 | 0.00010 |
| Krypton | Kr | 0.0000010 | 0.0001 | 83.798 | 0.000084 | 0.00029 |
| Hydrogen | H2 | 0.0000005 | 0.00005 | 2.016 | 0.000001 | 0.000003 |
| Xenon | Xe | 0.00000009 | 0.000009 | 131.293 | 0.000012 | 0.00004 |
| Average molar mass of air | 28.9647 | |||||
- 1 kg = 2.2046 lb
Air Density
The density of dry air can be calculated with the Ideal Gas Law
ρ = P / (R T) (1)
P = pressure (Pa)
Rair = 287.05 = individual gas constant (J/kg K)
T = absolute temperature (K)
Example: The density of dry air at atmospheric pressure 101.325 kPa (101325 Pa) and 0 oC (273.15 K) can be calculated as
ρ = (101325 Pa) / ((287.05 J/kg K) (273.15 K))
= 1.292 (kg/m3)
Water Vapor
Water vapor is almost always present in air. The content may vary and the maximum amount possible of water vapor in dry air depends on the temperature of the air.
Water vapor - H2O - is composed of one oxygen atom and two hydrogen atoms. Hydrogen is the lightest element with a molar mass of 1 g/mol, while oxygen has 16 g/mol . Thus, the water vapor atom has an molar mass of 18 g/mol, and water vapor is lighter than O2with 32 g/mol and N2with 28 g/mol .
- Note! Water vapor in air will dilute the other gases and reduce the total density of the mixture. Dry air is more dense than humid air!
The vapor in air may saturate to droplets when temperature is decreased or pressure is increased.
Humid air containing water molecules as liquid - droplets - may be more dense than dry air or humid air containing water only as vapor.
• Air Psychrometrics
• Gases and Compressed Air
Air - Prandtl Number
Air - Specific Heat Ratio
Specific Heat Ratio of air at temperatures ranging -40 - 1000 degC (-40 - 1500 degF) at standard atmospheric pressure - Imperial and SI Units.
Air - Speed of Sound vs. Temperature
Speed of sound in air at standard atmospheric pressure with temperatures ranging -40 to 1000 °C (-40 to 1500 °F) - Imperial and SI Units.
Air Properties: Temperature, Pressure & Density Data
Density of Gases
Dry Air Thermodynamic and Physical Properties – Density, Specific Heat, Viscosity
THe essential thermodynamic properties of dry air like specific heat, ratio of specific heats, dynamic viscosity, thermal conductivity, Prandtl number, density and kinematic viscosity at temperatures ranging 175 - 1900 K.
Gas Mixtures - Properties
Gas mixtures and the ideal gas law, mass calculations, the individual gas constant and density.
Gases - Molar Specific Heats
Molar specific heats for some common gases at constant volume.
Humid Air and the Ideal Gas Law
Pressure, temperature and volume in a perfect ideal gas like moist air (air with water vapor).
Individual & Universal Gas Constants: Definitions, Values, and Applications
Moist Air - Mole Fraction of Water Vapor
Mole fraction of water vapor is the ratio of water molecules to air and water molecules.
Mole and the Avagadro's Number
The mole is the SI base unit for an amount of a substance.
Specific Heat Capacity of Air: Isobaric and Isochoric Heat Capacities at Various Temperatures and Pressures
Online calculator with figures and tables showing specific heat (Cp and Cv) of dry air vs. temperature and pressure. SI and imperial units.
The Ideal Gas Law
