Fick's first law states that a substance will flow from a region with high concentration to a region of low concentration. Fick's law can be expressed as
J = -D dφ/dx (1)
J = diffusion flux - the amount of substance that flows through an unit area per unit time (mass or mol/(m2s))
D = diffusion coefficient (m2/s)
dφ = change in concentration of substance (mass or mol/m3)
dx = change in length (m)
For simple one-dimensional transport, the diffusion coefficient describes the time–rate of change of concentration. The diffusion coefficient varies from substance to substance and with temperature and pressure.
Figure and table below shows the diffusion coefficients, D12 , for binary gas mixtures where air is in large excess.
See also Air Composition and molecular weight, Density at varying pressure, Density and specific weight at varying temperature, Diffusion coefficients for gases in air, Dynamic (absolute) and kinematic viscosity, Prandtl Number, Specific heat at varying temperature and Specific heat at varying pressure, Thermal conductivity, Thermal diffusivity, Properties at gas-liquid equilibrium conditions and Air properties, for other properties of air, as well as Diffusion coefficients of gases in water and Carbon dioxide concentrations in rooms with people
| Gases in large excess of air | Diffusion coefficient, D12 , (cm2/s) at atmospheric pressure and given temperatures | ||||||
| 0 °C | 20 °C | 100 °C | 200 °C | 300 °C | 400 °C | ||
| Name | Formula | 32 °F | 68 °F | 212 °F | 392 °F | 572 °F | 752 °F |
| Argon | Ar | 0.167 | 0.189 | 0.289 | 0.437 | 0.612 | 0.81 |
| Methane | CH4 | 0.21 | 0.321 | 0.485 | 0.678 | 0.899 | |
| Carbon monoxide | CO | 0.208 | 0.315 | 0.475 | 0.662 | 0.875 | |
| Carbon dioxide | CO2 | 0.16 | 0.252 | 0.39 | 0.549 | 0.728 | |
| Hydrogen | H2 | 0.668 | 0.756 | 1.153 | 1.747 | 2.444 | 3.238 |
| Water vapour | H2O | 0.219 | 0.242 | 0.399 | 0.638 | 0.873 | 1.135 |
| Helium | He | 0.617 | 0.697 | 1.057 | 1.594 | 2.221 | 2.933 |
| Sulfur hexafluoride | SF6 | 0.15 | 0.233 | 0.329 | 0.438 | ||
• Air Psychrometrics
• Gases and Compressed Air
Air - Humidity Ratio
Air - Prandtl Number
Air - Speed of Sound vs. Temperature
Speed of sound in air at standard atmospheric pressure with temperatures ranging -40 to 1000 °C (-40 to 1500 °F) - Imperial and SI Units.
Air Conditioning - Cooling of Air and Condensate Generated
Water may condensate when air is cooled in air conditioning systems.
Air Properties: Temperature, Pressure & Density Data
Carbon Dioxide Concentration in Rooms Occupied with People
Carbon dioxide concentration in a room may indicate air quality and ventilation system efficiency.
Pressure loss in compressed air pipe lines.
Dry Air Thermodynamic and Physical Properties – Density, Specific Heat, Viscosity
THe essential thermodynamic properties of dry air like specific heat, ratio of specific heats, dynamic viscosity, thermal conductivity, Prandtl number, density and kinematic viscosity at temperatures ranging 175 - 1900 K.
Moist Air - Specific Volume
Specific volume of moist air is defined as the total volume of humid air per mass unit of dry air
Moist Air - Weight of Water Vapor
Weight of water vapor in air
Solubility of Air in Water
The amount of air that can be dissolved in water decreases with temperature and increases with pressure.
Specific Heat Capacity of Air: Isobaric and Isochoric Heat Capacities at Various Temperatures and Pressures
Online calculator with figures and tables showing specific heat (Cp and Cv) of dry air vs. temperature and pressure. SI and imperial units.
