Moist Air - Specific Volume
When discussing specific volume of moist air its necessary to differentiate between
- specific volume of moist air per mass unit of dry air , or
- specific volume of moist air per mass unit of dry air and water vapor
Specific Volume of Moist Air per Mass Unit of Dry Air
Specific volume is defined as the total volume of dry air and water vapor mixture per kg of dry air (SI-units). The specific volume can be expressed as
v da = V / m a (1)
v da = specific volume of moist air per mass unit of dry air (m 3 /kg)
V = total volume of moist air (m 3 )
m a = mass of dry air (kg)
When dry air and water vapor with the same temperature occupies the same volume the equation for an ideal gas can be applied.
p a V = m a R a T (2)
p a = partial pressure of dry air (Pa)
R a = 286.9 - the individual gas constant dry air (J/kg.K)
T = temperature of the moist air (K)
Combining (1) and (2):
v da = R a T / p a (3)
The partial pressure of the air can be expressed as
p a = p - p w (3b)
p = pressure in the moist air (Pa)
p w = partial pressure water vapor (Pa)
Combining (3) and (2):
v da = R a T / (p - p w ) (3c)
The ideal gas law can also be applied to the water vapor as
p w V = m w R w T (4)
p w = partial pressure of water vapor (Pa)
R w = individual gas constant water vapor ( 461.4 J/kg.K)
The mass of the water vapor can be calculated by using the humidity ratio and the mass of air as
m w = x m a (5)
x = m w / m a = specific humidity or humidity ratio (kg h2o /kg dry_air )
m w = mass of water vapor (kg)
Combining (4) and (5):
p w V = x m a R w T (6)
Combining (6) with (1):
v da = x R w T / p w (7)
Transforming (7):
p w = x R w T / v da (8)
Combining (8) with (3c):
v da = R a T / (p - (x R w T / v da )) (9)
(9) can be transformed to express the specific volume of moist air per unit mass of dry air as
v da = (1 + x R w / R a ) R a T / p (10)
Specific Volume of Moist Air per unit Mass of Dry Air and Water Vapor
Specific volume is defined as the total volume of dry air and water vapor mixture per kg of dry air and water vapor (SI-units). The specific volume can be expressed as:
v = V / m a + m w (11)
v = specific volume of moist air per mass unit of dry air and water vapor (m 3 /kg)
Combining with (5):
v = V / m a (1 + x) (12)
Combining with (1):
v = v da / (1 + x) (13)
and the specific volume of moist air per unit mass of dry air and water vapor (moist air) can be expressed as
v = (R a T / p) [(1 + x R w / R a )/ (1 + x)] (14)
(14) can used to express the inverse of the specific volume - the density - of moist air as
ρ = 1 / v
= (p / R a T) (1 + x) / (1 + x R w / R a ) (15)
• Air Psychrometrics
Air - Density vs. Pressure and Temperatures
Air - Dynamic and Kinematic Viscosity
Air - Humidity Ratio
Air - Prandtl Number
Humid Air vs. the Ideal Gas Law
Pressure, temperature and volume in a perfect ideal gas like moist air (air with water vapor).
Moist Air - Daltons Law of Partial Pressure
The pressure in a mixture of dry air and water vapor - humid or moist air - can be estimated by using Daltons Law of partial pressures.
Moist Air - Density vs. Pressure
Density of moist air vs. pressure ranging 75 - 1000 mmHg.
Moist Air - Properties
Psychrometric table with humid air properties like saturation pressure, specific volume, enthalpy and entropy.
Moist Air - Psychrometric Table for Pressure 29.92 inHg
Dry and wet bulb temperatures, saturation pressure, water vapor weight, specific volume, heat and more.
Moist Air - Psychrometric Terms
Dry and wet bulb temperature, specific volume, relative humidity, enthalpy and more.
Moist Air - Specific vs. Relative Humidity
Specific humidity of moist air vs. relative humidity, water vapor and air density.
Moist Air - Weight of Water Vapor
Weight of water vapor in air
