Density is the ratio of the mass to the volume of a substance:
ρ = m / V (1)
ρ = density, units typically (kg/m3) or (lb/ft3)
Specific weight is the ratio of the weight to the volume of a substance:
γ = m g / V
= ρ g (2)
γ = specific weight, units typically (N/m3) or (lbf/ft3)
m = mass, units typically (g) or (lb)
g = acceleration due to gravity, units typically (m/s2) and value on Earth usually given as 9.80665 m/s2or 32.17405 ft/s2
V = volume, units typically (cm3) or (ft3)
ρ = density, units typically (g/cm3) or (lb/ft3)
Tabulated values and density units conversion are given below the figures . At the bottom of the page there are some examples of calculations using hot and cold air.
See also Air Composition and molecular weight, Density at varying pressure , Diffusion Coefficients for Gases in Air, Dynamic (absolute) and kinematic viscosity, Prandtl Number, Specific heat at varying temperature and Specific heat at varying pressure, Thermal Conductivity, Thermal Diffusivity, Properties at gas-liquid equilibrium conditions and Air thermophysical properties, for other properties of air .
For other substances, see Density and specific weight o acetone, ammonia, argon, benzene, butane, carbon dioxide, carbon monoxide, ethane, ethanol, ethylene, helium, hydrogen, methane, methanol, nitrogen, oxygen, pentane, propane, toluene and water, as well as Density of crude oil , Density of fuel oils , Density of lubricating oil and Density of jet fuel as function of temperature.
Online Air Density Calculator
The calculator below can be used to calculate the air density and specific weight at given temperatures and atmospheric pressure.
The output density is given as kg/m3, lb/ft3, lb/gal(US liq) and sl/ft3. Specific weight is given as N/m3 and lbf/ft3.
Note! Temperature must be within the ranges -100 - 1600 °C, -140 - 2900 °F, 175 - 1900 K and 315 - 3400 °R to get valid values.
Air density and specific weight at atmospheric pressure:
Air density at ambient temperature and pressure:
Air density at varying pressure and temperature:
Air density at gas-liquid equilibrium pressure:
Air thermal expansion coefficient at atmospheric pressure:
Density, specific weight and thermal expansion coefficient of air at 1 atmosphere pressure, at temperatures given as °F:
For full table specific weight and thermal expansion coefficient - rotate the screen!
| Temperature | Density | Specific weight | Thermal expansion coefficient | ||||
| (°F) | (lbm/ft3) | (slugs/ft3×10-3) | (lbm/gal(US liq)) | (kg/m3) | (lbf/ft3) | (N/m3) | (×10-3 °F-1) |
| -100 | 0.1104 | 3.431 | 0.01476 | 1.768 | 0.1104 | 17.34 | 2.83 |
| -50 | 0.0968 | 3.010 | 0.01295 | 1.551 | 0.0968 | 15.21 | 2.48 |
| -20 | 0.0902 | 2.803 | 0.01206 | 1.445 | 0.0902 | 14.17 | 2.30 |
| 0 | 0.0862 | 2.681 | 0.01153 | 1.382 | 0.0862 | 13.55 | 2.20 |
| 10 | 0.0844 | 2.624 | 0.01128 | 1.352 | 0.0844 | 13.26 | 2.15 |
| 20 | 0.0826 | 2.569 | 0.01105 | 1.324 | 0.0826 | 12.98 | 2.10 |
| 30 | 0.0810 | 2.516 | 0.01082 | 1.297 | 0.0810 | 12.72 | 2.06 |
| 40 | 0.0793 | 2.466 | 0.01061 | 1.271 | 0.0793 | 12.46 | 2.02 |
| 50 | 0.0778 | 2.418 | 0.01040 | 1.246 | 0.0778 | 12.22 | 1.98 |
| 60 | 0.0763 | 2.372 | 0.01020 | 1.222 | 0.0763 | 11.99 | 1.94 |
| 70 | 0.0749 | 2.327 | 0.01001 | 1.199 | 0.0749 | 11.76 | 1.90 |
| 80 | 0.0735 | 2.284 | 0.00982 | 1.177 | 0.0735 | 11.55 | 1.87 |
| 100 | 0.0709 | 2.203 | 0.00948 | 1.135 | 0.0709 | 11.14 | 1.80 |
| 120 | 0.0685 | 2.128 | 0.00915 | 1.097 | 0.0685 | 10.75 | 1.74 |
| 140 | 0.0662 | 2.057 | 0.00885 | 1.060 | 0.0662 | 10.40 | 1.68 |
| 160 | 0.0641 | 1.991 | 0.00856 | 1.026 | 0.0641 | 10.06 | 1.63 |
| 180 | 0.0621 | 1.929 | 0.00830 | 0.994 | 0.0621 | 9.75 | 1.58 |
| 200 | 0.0602 | 1.870 | 0.00804 | 0.964 | 0.060 | 9.45 | 1.53 |
| 250 | 0.0559 | 1.738 | 0.00747 | 0.896 | 0.0559 | 8.78 | 1.41 |
| 300 | 0.0522 | 1.622 | 0.00698 | 0.836 | 0.0522 | 8.20 | 1.30 |
| 350 | 0.0489 | 1.521 | 0.00654 | 0.784 | 0.0489 | 7.69 | 1.23 |
| 400 | 0.0461 | 1.432 | 0.00616 | 0.738 | 0.0461 | 7.24 | 1.16 |
| 450 | 0.0436 | 1.354 | 0.00582 | 0.698 | 0.0436 | 6.84 | 1.10 |
| 500 | 0.0410 | 1.274 | 0.00548 | 0.656 | 0.0410 | 6.43 | 1.05 |
| 600 | 0.0371 | 1.152 | 0.00496 | 0.599 | 0.0371 | 5.82 | 0.96 |
| 700 | 0.0340 | 1.057 | 0.00455 | 0.545 | 0.0340 | 5.35 | 0.88 |
| 800 | 0.0315 | 0.978 | 0.00421 | 0.5042 | 0.0315 | 4.94 | 0.81 |
| 1000 | 0.0272 | 0.845 | 0.00363 | 0.4354 | 0.0272 | 4.27 | 0.70 |
| 1200 | 0.0239 | 0.743 | 0.00319 | 0.3827 | 0.0239 | 3.75 | 0.61 |
| 1400 | 0.0213 | 0.663 | 0.00285 | 0.3416 | 0.0213 | 3.35 | 0.54 |
| 1600 | 0.0193 | 0.599 | 0.00257 | 0.3085 | 0.0193 | 3.03 | 0.49 |
| 1800 | 0.0176 | 0.546 | 0.00235 | 0.2813 | 0.0176 | 2.76 | 0.45 |
| 2000 | 0.0161 | 0.501 | 0.00216 | 0.2583 | 0.0161 | 2.53 | 0.42 |
Density and specific weight of air at 1 atmosphere pressure, at temperatures given as °C:
| (°C) | (kg/m3) | (lbm/ft3) | (sl/ft3 ×10-3) | (lbm/gal(US liq)) | (N/m3) | (lbf/ft3) | (×10-3 K-1) |
| -75 | 1.783 | 0.1113 | 3.460 | 0.01488 | 17.49 | 0.11131 | 5.14 |
| -50 | 1.582 | 0.0988 | 3.070 | 0.01320 | 15.52 | 0.09878 | 4.55 |
| -25 | 1.422 | 0.0888 | 2.759 | 0.01187 | 13.94 | 0.08877 | 4.08 |
| -15 | 1.367 | 0.0853 | 2.652 | 0.01141 | 13.40 | 0.08532 | 3.92 |
| -10 | 1.341 | 0.0837 | 2.601 | 0.01119 | 13.15 | 0.08370 | 3.84 |
| -5 | 1.316 | 0.0821 | 2.553 | 0.01098 | 12.90 | 0.08214 | 3.76 |
| 0 | 1.292 | 0.0806 | 2.506 | 0.01078 | 12.67 | 0.08063 | 3.69 |
| 5 | 1.268 | 0.0792 | 2.461 | 0.01059 | 12.44 | 0.07919 | 3.62 |
| 10 | 1.246 | 0.0778 | 2.418 | 0.01040 | 12.22 | 0.07780 | 3.56 |
| 15 | 1.225 | 0.0765 | 2.376 | 0.01022 | 12.01 | 0.07645 | 3.50 |
| 20 | 1.204 | 0.0752 | 2.336 | 0.01005 | 11.81 | 0.07516 | 3.43 |
| 25 | 1.184 | 0.0739 | 2.297 | 0.00988 | 11.61 | 0.07390 | 3.38 |
| 30 | 1.164 | 0.0727 | 2.259 | 0.00972 | 11.42 | 0.07269 | 3.32 |
| 40 | 1.127 | 0.0704 | 2.188 | 0.00941 | 11.06 | 0.07039 | 3.21 |
| 50 | 1.093 | 0.0682 | 2.120 | 0.00912 | 10.72 | 0.06822 | 3.12 |
| 60 | 1.060 | 0.0662 | 2.057 | 0.00885 | 10.40 | 0.06619 | 3.02 |
| 80 | 1.000 | 0.0625 | 1.941 | 0.00835 | 9.81 | 0.06245 | 2.85 |
| 100 | 0.9467 | 0.0591 | 1.837 | 0.00790 | 9.28 | 0.05910 | 2.70 |
| 125 | 0.8868 | 0.0554 | 1.721 | 0.00740 | 8.70 | 0.05536 | 2.51 |
| 150 | 0.8338 | 0.0521 | 1.618 | 0.00696 | 8.18 | 0.05206 | 2.33 |
| 175 | 0.7868 | 0.0491 | 1.527 | 0.00657 | 7.72 | 0.04912 | 2.22 |
| 200 | 0.7451 | 0.0465 | 1.446 | 0.00622 | 7.31 | 0.04651 | 2.10 |
| 225 | 0.7078 | 0.0442 | 1.373 | 0.00591 | 6.94 | 0.04419 | 2.01 |
| 300 | 0.6168 | 0.0385 | 1.197 | 0.00515 | 6.05 | 0.03850 | 1.76 |
| 400 | 0.5238 | 0.0327 | 1.016 | 0.00437 | 5.14 | 0.03270 | 1.52 |
| 500 | 0.4567 | 0.0285 | 0.886 | 0.00381 | 4.48 | 0.02851 | 1.32 |
| 600 | 0.4043 | 0.0252 | 0.784 | 0.00337 | 3.96 | 0.02524 | 1.16 |
| 700 | 0.3626 | 0.0226 | 0.704 | 0.00303 | 3.56 | 0.02264 | 1.03 |
| 800 | 0.3289 | 0.0205 | 0.638 | 0.00274 | 3.23 | 0.02053 | 0.94 |
| 900 | 0.3009 | 0.0188 | 0.584 | 0.00251 | 2.95 | 0.01879 | 0.86 |
| 1000 | 0.2773 | 0.0173 | 0.538 | 0.00231 | 2.72 | 0.01731 | 0.80 |
| 1100 | 0.2571 | 0.0160 | 0.499 | 0.00215 | 2.52 | 0.01605 | 0.75 |
Example - Mass of Air at Temperature 100 oC
From the table above - the density of air is 0.946 kg/m3 at 100 oC. The mass of 10 m3 air can be calculated as
m = V ρ
= (10 m3) (0.946 kg/m3)
= 9.46 (kg)
m = mass (kg)
V = volume (m3)
ρ = density (kg/m3)
Example - Mass of Air at Temperature 20 oC
From the table above - the density of air is 1.205 kg/m3 at 20 oC. The mass of 10 m3 air can be calculated as
m = (10 m3) (1.205 kg/m3)
= 12.05 (kg)
Example - Lifting Force of a Hot Air Balloon
An air balloon with volume 10 m3 is heated to 100 oC. The temperature of the surrounding air is 20 oC. The change in gravity force (weight) of the air volume is the potential lifting force of the balloon. The lifting force can be calculated as
Fl = dm ag
= V dρ ag
= (10 m3) (1.205 - 0.946) (kg/m3) (9.81 m/s2)
= 25.4 (N)
Fl = lifting force - change in gravity force (weight) (N)
ag = acceleration of gravity (9.81 m/s2)
dm = V dρ = change of mass in the balloon (kg)
dρ = change in density due to temperature difference (kg/m3)
• Air Psychrometrics
• Densities
• Gases and Compressed Air
Acetone - Density and Specific Weight
Online calculator, figures and tables showing density and specific weight of acetone at temperatures ranging from -95 to 275 °C (-138 to 530 °F) at atmospheric and higher pressure - Imperial and SI Units.
Density and specific volume of air varies with elevation above sea level.
Air - Humidity Ratio
Air - Prandtl Number
Air - Speed of Sound vs. Temperature
Speed of sound in air at standard atmospheric pressure with temperatures ranging -40 to 1000 °C (-40 to 1500 °F) - Imperial and SI Units.
Air Conditioning - Cooling of Air and Condensate Generated
Water may condensate when air is cooled in air conditioning systems.
Air Properties: Temperature, Pressure & Density Data
Online calculator, figures and table showing density and specific weight of benzene, C6H6, at temperatures ranging from 5 to 325 °C (42 to 620 °F) at atmospheric and higher pressure - Imperial and SI Units.
Pressure loss in compressed air pipe lines.
Dry Air Thermodynamic and Physical Properties – Density, Specific Heat, Viscosity
THe essential thermodynamic properties of dry air like specific heat, ratio of specific heats, dynamic viscosity, thermal conductivity, Prandtl number, density and kinematic viscosity at temperatures ranging 175 - 1900 K.
Latent Heat Flow
Online calculator, figures and tables showing density and specific weight of methanol,CH3OH, at varying temperature and pressure - Imperial and SI Units.
Moist Air - Specific Volume
Specific volume of moist air is defined as the total volume of humid air per mass unit of dry air
Moist Air - Weight of Water Vapor
Weight of water vapor in air
Nitrogen (N₂) Density & Specific Weight: Temperature & Pressure Data and Calculator
Online calculator, figures and tables showing density and specific weight of nitrogen, N2, at temperatures ranging from -175 to 1325 °C (-280 to 2400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Solubility of Air in Water
The amount of air that can be dissolved in water decreases with temperature and increases with pressure.
Specific Heat Capacity of Air: Isobaric and Isochoric Heat Capacities at Various Temperatures and Pressures
Online calculator with figures and tables showing specific heat (Cp and Cv) of dry air vs. temperature and pressure. SI and imperial units.
Stack or Flue Effect
The stack or flue effect occurs when the outdoor temperature is lower than indoor temperature.
U.S. Standard Atmosphere: Temperature, Pressure, and Air Properties vs. Altitude
Properties of the US standard atmosphere ranging -5000 to 250000 ft altitude.
Wind Power
Power generation from wind.
