Correlations for fuel oils density and temperature are calculated by use of tools based on ASTM D 1250-04 and IP 200/04 (API Manual of Petroleum Measurement Standards, Chapter 11- physical properties Data, Section 1:Temperature and pressure volume correction factors for generalized crude oils, refined products and lubricating oils).
Examples of the use of the figures are given below the figures.
If you have the fuel oil density given in °API, use the API-to-gravity converter .
See also similar correlations for lubricating oil, crude oil and jet fuel.
Fuel Densities - Volume Correction vs. Temperature
The diagrams below can be used to estimate fuel oil densities at other temperatures than specified.
Example - The density of a fuel oil is specified to be 900 kg/m3 at 15 oC - which corresponds to the yellow line in the diagram. The density of the same oil heated to 100 oC is by following the yellow line approximately 840 kg/m3.
Volume correction factors can be used to calculate the volume of a product at base temperature (15°C/59°F) if  you know the density and volume at another temperature. Or, if you know the base volume and density, you can use the volume correction factor to calculate the volume at another temperature. To be sure you have used the correct figure for correction factors, the easy rule is that the volume increases with increasing temperature.
Examples of the use:
1.
You have 100 liters of a fuel oil with a density of 800 kg/m3 at 200°C. How is the volume at 15°C?
In the Density vs temperature figure(°C), you se that the light blue line represent this fuel oil.
Then, use the light blue line in the Fuel oils volume correction figure (Density@Observed T/Density@15°C). At 200°C the correction factor is 0.859.
The volume of your fuel oil at 15°C is 100liters*0.859 = 86 liters. (Easy check: Lowest volume at the lowest temperature)
2.
You have 1000 m3 of a fuel oil with a density of 960 kg/m3 at 15°C. How will the volume change if you heat it to 100°C?
In the Density vs temperature figure (°C), you see that the light green line represent this fuel oil.
Then use the light green line in the Fuel oils volume correction figure (Density@15°C/Density@observed T). At 100°C the correction factor is 1.065.
The volume of your fuel oil at 100°C is 1000m3 *1.065 = 1065 m3. (Easy check: Lowest volume at the lowest temperature)
Densities
Material Properties
Properties of alternative fuels like biodiesel, E85, CNG and more.
API Gravity: Definition, Calculation, and Converter
API expresses the gravity or density of liquid petroleum products. Online API to Specific Gravity calculator.
Crude Oil Properties - Standard test methods (ASTM and others)
An overview of common test methods and typical ranges of variation of petroleum quality parameters. What, why and how do the different test?
Density Converter
Gasoline - Density, Specific Heat, Viscosity and Thermal Conductivity vs. Temperature
Hydrocarbon Mixtures - Average Boiling Points vs. Gravity and Molecular Weights
Formulas and examples of calculation of boiling point of hydrocarbon mixtures from gravity and molecular weight.
Hydrocarbon Mixtures - Molecular Weight vs. Gravity and Average Boiling Point
Formulas and examples of calculation of average molecular weight of hydrocarbon mixtures from gravity and average boiling point, achieved from distillation data.
Hydrocarbons - Physical Data
Liquid Densities
Liquid-Liquid Solution - Shrinkage and Estimation of Density
It is possible to estimate the density of a liquid-liquid solution from the density of the solute and the solvent. However, due to shrinkage, the estimate will be a bit too low.
Liquids - Specific Gravities
Specific gravities of liquids like alcohol, oils, benzene, water and many more.
Organic Nitrogen Compounds - Physical Data
Boiling and melting points of amines, diamines, pyrroles, pyridines, piperidines and quinolines shown together with their molecular structures, as well as molweights and density.
Organic Sulfur Compounds - Physical Data
Boiling and melting points of thoils, sulfides, disulfides and thiophenes shown together with molecular structures, as well as molweights and density.
Petroleum Products - Average Boiling Points
Definition, explanation and examples of calculation of various types of average boiling point of petroleum products and other mixtures of hydrocarbons: VABP, MABP, WABP, CABP and MeABP.
Petroleum Products - Standard Test Methods (ASTM and others) and Specifications
An overview of common test methods and specifications of petroleum fuels. What, why and how do the different test?
Solids - Densities
Densities of selected solids.
Yield Structure of Crude Oils with Increasing Density of Crude
Yields of different crude oil distillation cuts are plotted as function of whole crude specific gravity. Fractions based on European and North American markets, and the typical differences in crude oil fractionation in the two markets are also shown.
