- t -
(oC)
Properties of alternative fuels like biodiesel, E85, CNG and more.
Raw materials used for Ethanol Bio-fuel production.
Environmental emission of carbon dioxide CO2 when combustion fuels like coal, oil, natural gas, LPG and bio energy.
Heating fuels and their energy content.
The flash points for some common liquids and fuels.
Net (low) and gross (high) energy content in fossil and alternative fuels.
Combustion heat values for gases like acetylene, blast furnace gas, ethane, biogas and more - Gross and Net values.
Fuels and their boiling points.
Densities and specific volumes fuels like anthracite, butane, gasoil, diesel, coke, oil, wood and more.
Higher and lower calorific values (heating values) for fuels like coke, oil, wood, hydrogen and others.
Definition, explanation and examples of calculation of various types of average boiling point of petroleum products and other mixtures of hydrocarbons: VABP, MABP, WABP, CABP and MeABP.
An overview of common test methods and specifications of petroleum fuels. What, why and how do the different test?
