Fuels - Densities and Specific Volumes
Density - ρ - and specific volume of some commonly used fuels:
| Fuel | Density@15°C - ρ - | Specific Volume - v - | ||
| (kg/m3) | (lb/ft3) | (m3/1000 kg) | (ft3 per ton) | |
| Anthracite | 720 - 850 | 45 - 53 | 1.2 - 1.4 | 42 - 50 |
| Bituminous coal | 690 - 800 | 43 - 50 | 1.2 - 1.5 | 45 - 52 |
| Butane (gas) | 2.5 | 0.16 | 400 | 14100 |
| Charcoal, hard wood | 149 | 9.3 | 6.7 | 240 |
| Charcoal, soft wood | 216 | 13.5 | 4.6 | 165 |
| Coke | 375 - 500 | 23.5 - 31 | 2.0 - 2.7 | 72 - 95 |
| Diesel 1D1) | 875 | 54.6 | 1.14 | 40.4 |
| Diesel 2D1) | 849 | 53 | 1.18 | 41.6 |
| Diesel 4D1) | 959 | 59.9 | 1.04 | 36.8 |
| EN 590 Diesel 2) | 820-845 | 51-53 | 1.18-1.22 |
42-43 |
| Gas oil | 825-900 | 51-56 | 1.1-1.2 | 36-43 |
| Gasoline | 715-780 |
45-49 |
1.3-1.4 | 45-49 |
| Fuel Oil No.13) | 750-850 | 47-53 | 1.2-1.3 | 42-47 |
| Fuel Oil No.23) | 810-940 | 51-59 | 1.1-1.2 | 38-44 |
| Heavy fuel oil | 800-1010 | 50-63 | 1.0-1.3 | 35-44 |
| Kerosene | 775-840 | 48-52 | 1.2-1.3 | 42-46 |
| Natural gas (gas) | 0.7 - 0.9 | 0.04-0.06 | 1110-1430 | 39200-50400 |
| Peat | 310 - 400 | 19.5 - 25 | 2.5 - 3.2 | 90 - 115 |
| Propane (gas) | 1.7 | 0.11 | 590 | 20800 |
| Wood | 360 - 385 | 22.5 - 24 | 2.5 - 2.8 |
90 - 100 |
Note 1) Diesel fuels are in USA broken up into 3 different classes: 1D, 2D and 4D. The difference between these classes depends on viscosity and boiling point ranges. 4D fuels tend to be used in low-speed engines. 2D fuels are used in warmer weather and are sometimes mixed with 1D fuel to create a competent winter fuel. 1D fuel is preferred for cold weather as it has a lower viscosity. It used to be standard to see the fuel number on the pump, but a lot of gas stations do not state the fuel number anymore.
Note 2) European diesel standard from 2005
Note 3) Fuel oil is a kind of product with a lot of classes and under classes as well as varying specifications in different markets. The density ranges given represents the variation, however, some products may be outside these ranges.
• Combustion
• Densities
Biomasses - Energy Content when Used as Fuel
Biomass fuels and their energy content.
Car Fuel Consumption - liter/100 km
Calculate fuel consumption in liter per km - consumption chart and calculator.
Crude Oil Properties - Standard test methods (ASTM and others)
An overview of common test methods and typical ranges of variation of petroleum quality parameters. What, why and how do the different test?
Density Converter
Fuels - Boiling Points
Fuels and their boiling points.
Fuels - Combustion Air and Flue Gases
Combustion air and flue gas for common fuels - coke, oil, wood, natural gas and more.
Gasoline - Density, Specific Heat, Viscosity and Thermal Conductivity vs. Temperature
Petroleum Products - Standard Test Methods (ASTM and others) and Specifications
An overview of common test methods and specifications of petroleum fuels. What, why and how do the different test?
