Density Converter
Density is an expression of the ratio of mass per unit volume . The symbol used for density is rho, ρ .
ρ = m / V (1)
ρ = density (kg/m3, lbm/ft3...)
m = mass (kg, lbm ..)
V = volume (m3, ft3..)
Density Converter
The calculator below can be used to convert between common density units:
See also Unit converter
Download and print density converting chart
Density Converting Table
The table below can be used to convert between density units:
For full table with more Units - rotate the screen!
Convert from | Multiply by | ||||||||||
Convert to | |||||||||||
kg/m3 | g/cm3 | oz/in3 | oz/gal(Imp) | oz/gal(US liq) | lb/ft3 | lb/in3 | lb/yd3 | lb/gal(Imp) | lb/gal(US liq) | long ton/yd3 | |
kg/m3 | 1 | 0.001 | 0.00057804 | 0.1604358 | 0.133526 | 0.062428 | 0.000036127 | 1.68555 | 0.0100224 | 0.00834540 | 0.000752548 |
g/cm3 | 1000 | 1 | 0.57804 | 160.4358 | 133.526 | 62.428 | 0.036127 | 1685.55 | 10.0224 | 8.34540 | 0.752548 |
oz/in3 | 1729.994 | 1.7329994 | 1 | 277.419 | 231 | 108 | 0.0625 | 2916 | 17.3387 | 14.4375 | 1.30179 |
oz/gal (Imp) | 6.23602 | 0.00623602 | 0.00360465 | 1 | 0.832674 | 0.389302 | 0.000225291 | 10.5112 | 0.0625 | 0.0520421 | 0.00469248 |
oz/gal (US liq) | 7.48915 | 0.00748915 | 0.00432900 | 1.20095 | 1 | 0.467532 | 0.000270563 | 12.6234 | 0.0750594 | 0.0625 | 0.00563544 |
lb/ft3 | 16.0185 | 0.0160185 | 0.00925926 | 2.56870 | 2.13889 | 1 | 0.000578704 | 27 | 0.160544 | 0.133681 | 0.0120536 |
lb/in3 | 27679.9 | 27.6799 | 16 | 4438.71 | 3696 | 1728 | 1 | 46656 | 277.419 | 231 | 20.8286 |
lb/yd3 | 0.593276 | 0.000593276 | 0.000342936 | 0.0951370 | 0.0792181 | 0.0370370 | 0.0000214335 | 1 | 0.00594606 | 0.00495113 | 0.000446429 |
lb/gal (Imp) | 99.7764 | 0.0997764 | 0.0576744 | 16 | 13.3228 | 6.22884 | 0.00360465 | 168.179 | 1 | 0.832674 | 0.0750797 |
lb/gal (US liq) | 119.826 | 0.119826 | 0.0692641 | 19.2152 | 16 | 7.48052 | 0.00432900 | 201.974 | 1.20095 | 1 | 0.0901670 |
long ton/yd3 | 1328.94 | 1.32894 | 0.768176 | 213.107 | 177.449 | 82.9630 | 0.0480110 | 2240 | 13.3192 | 11.0905 | 1 |
- kg/m3 - kilogram per cubic metre
- g/cm3 - gram per cubic centimetre
- oz/in3 - ounce per cubic inch
- oz/gal (Imp) - ounce per imperial gallon
- oz/gal (US liq) - ounce per U.S. liquid gallon
- lb/ft3 - pound per cubic foot
- lb/in3 - pound per cubic inch
- lb/yd3 - pound per cubic yard
- lb/gal (Imp) - pound per imperial gallon
- lb/gal (US liq) - pound per U.S. liquid gallon
- long ton/yd3 - long ton (=imperial ton) per cubic yard
• Densities
Acetone - Density and Specific Weight
Online calculator, figures and tables showing density and specific weight of acetone at temperatures ranging from -95 to 275 °C (-138 to 530 °F) at atmospheric and higher pressure - Imperial and SI Units.
Online calculator, figures and table showing density and specific weight of benzene, C6H6, at temperatures ranging from 5 to 325 °C (42 to 620 °F) at atmospheric and higher pressure - Imperial and SI Units.
Concentration Units Converter
Calculator and formulas for conversion between different units of concentration: Molarity, molality, mole fraction, weight percent of solute and grams of solute per liter of solution - descriptive terms for solubility.
Crude Oil Viscosity vs. Gravity
Viscosity at 20°C/68°F and 50°C/122°F for more than 120 crudes is shown as function of specific gravity@15°C/60°F.
Densities of common Products
Densities of common products - Imperial and SI-units.
Density of Gases
Dirt and Mud - Densities
Densities - pound per cubic foot and kilograms per cubic metre - of dirt and mud.
Ditch Filling Materials - Densities
Weight or density of ditch filling materials.
Fuels - Densities and Specific Volumes
Densities and specific volumes fuels like anthracite, butane, gasoil, diesel, coke, oil, wood and more.
Hydrocarbons - Physical Data
Liquid Densities
Online calculator, figures and tables showing density and specific weight of methanol,CH3OH, at varying temperature and pressure - Imperial and SI Units.
Minerals - Densities
Densities of minerals.
Nitrogen (N₂) Density & Specific Weight: Temperature & Pressure Data and Calculator
Online calculator, figures and tables showing density and specific weight of nitrogen, N2, at temperatures ranging from -175 to 1325 °C (-280 to 2400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Petroleum Products - Standard Test Methods (ASTM and others) and Specifications
An overview of common test methods and specifications of petroleum fuels. What, why and how do the different test?
Common converting units for Acceleration, Area, Density, Energy, Energy per unit mass, Force, Heat flow rate, Heat flux, Heat generation per unit volume and many more.
Unit Factor Method
Water - Properties vs. Temperature and Pressure
Liquid water properties at temperatures between melting point and boiling point and pressures of 14.7 psia, 1000 psia and 10000 psia (1 atm, 68.1atm and 681 atm).
