Be aware of the concentration units in the figures:
wt%: Mass of solute/total mass of solution ×100%
mol/kg: Molality = moles of solute/kg of water
mol/liter: Molarity = moles of solute/liter of solution
Values are tabulated below the figures.
See also density of aqueous solutions of inorganic chlorides, inorganic sodium salts, some other inorganic substances, organic acids and organic substances as sugars and alcohols.
Density of aqueous solutions at 20°C, given as g/cm3:
For full table with Potassium Hydrogen Carbonate, Potassium Hydrogen Phosphate, Potassium Hydroxide, Potassium Iodide, Potassium Nitrate, Potassium Permanganate and Potassium Sulfate - rotate the screen!
Aqueous Solutions of Inorganic Potassium Salts - Densities
Mass%Potassium bromidePotassium carbonatePotassium chloridePotassium dihydrogen phosphatePotassium hydrogen carbonatePotassium hydrogen phosphatePotassium hydroxidePotassium iodidePotassium nitratePotassium permanganatePotassium sulfate
1 1.0054 1.0072 1.0046 1.0053 1.0046 1.0068 1.0068 1.0056 1.0045 1.0051 1.0062
5 1.035 1.0437 1.0304 1.0342 1.031 1.0412 1.0419 1.036 1.0298 1.0322 1.0388
10 1.074 1.0904 1.0633 1.0703 1.065 1.068 1.0873 1.0762 1.0627 1.0806
20 1.1601 1.1898 1.1328 1.1372 1.1818 1.1659 1.1326
30 1.2593 1.2755 1.2813 1.2712
40 1.3746 1.4142 1.3881 1.3959
50 1.5404 1.5024
Density at 20°C, given as g/cm3
Conversion of the concentration from mass% to mol/kg (moles of solute/kg of water = molality):
Aqueous Solutions of Inorganic Potassium Salts - Densities - Conversion of the concentration from mass% to mol/kg
1 0.085 0.073 0.135 0.074 0.101 0.058 0.18 0.061 0.1 0.064 0.058
5 0.442 0.381 0.706 0.387 0.526 0.302 0.938 0.317 0.521 0.333 0.302
10 0.934 0.804 1.490 0.816 1.11 0.499 1.98 0.669 1.099 0.638
20 2.101 1.809 3.353 2.497 4.456 1.506 2.473
30 3.601 2.814 7.639 2.582
40 5.602 4.824 11.882 4.016
50 7.236 17.82
Molality at 20°C, given as mol/kg water
Conversion of the concentration from mass% to mol/liter (moles of solute/liter of solution = molarity):
Aqueous Solutions of Inorganic Potassium Salts - Densities - Conversion of the concentration from mass% to mol/liter
1 0.084 0.073 0.135 0.074 0.1 0.058 0.179 0.061 0.099 0.064 0.058
5 0.435 0.378 0.691 0.380 0.515 0.299 0.929 0.312 0.509 0.327 0.298
10 0.903 0.789 1.426 0.786 1.064 0.491 1.938 0.648 1.051 0.62
20 1.95 1.722 3.039 2.272 4.213 1.405 2.24
28 3.175 2.584 6.851 2.297
40 4.62 4.03 9.896 3.364
50 5.573 13.389
Molarity at 20°C, given as mol/l solution
Densities
Material Properties
API Gravity: Definition, Calculation, and Converter
API expresses the gravity or density of liquid petroleum products. Online API to Specific Gravity calculator.
Concentration Units Converter
Calculator and formulas for conversion between different units of concentration: Molarity, molality, mole fraction, weight percent of solute and grams of solute per liter of solution - descriptive terms for solubility.
Density Converter
Liquid Densities
Liquid-Liquid Solution - Shrinkage and Estimation of Density
It is possible to estimate the density of a liquid-liquid solution from the density of the solute and the solvent. However, due to shrinkage, the estimate will be a bit too low.
Liquids - Specific Gravities
Specific gravities of liquids like alcohol, oils, benzene, water and many more.
Solids - Densities
Densities of selected solids.
Solutions, Molarity and Dilution
Definitions and examples of how to calculate wt%, molarity and how to prepare dilutions.
