Mass% | Sodium acetate | Sodium bromide | Sodium carbonate | Sodium chloride | Sodium citrate dihydrate | Sodium dihydrogen phosphate | Sodium hydrogen carbonate | Sodium hydrogen phosphate | Sodium hydroxyde | Sodium nitrate | Sodium phosphate | Sodium sulfate | Sodium thiosulfate |
1 | 1.0034 | 1.006 | 1.0086 | 1.0053 | 1.0049 | 1.0056 | 1.0054 | 1.0082 | 1.0095 | 1.005 | 1.01 | 1.0071 | 1.0065 |
5 | 1.0234 | 1.038 | 1.0502 | 1.034 | 1.0331 | 1.0358 | 1.0337 | 1.048 | 1.0538 | 1.0322 | 1.0579 | 1.0436 | 1.0399 |
10 | 1.0495 | 1.0803 | 1.1029 | 1.0707 | 1.0708 | 1.0747 | 1.1089 | 1.0674 | 1.0905 | 1.0827 | |||
20 | 1.1050 | 1.1745 | 1.1478 | 1.1492 | 1.1576 | 1.2192 | 1.1429 | 1.1907 | 1.174 | ||||
30 | 1.1602 | 1.2842 | 1.2488 | 1.3277 | 1.2256 | 1.2739 | |||||||
40 | 1.4138 | 1.3493 | 1.4299 | 1.3175 | 1.3827 | ||||||||
Density at 20°C, given as g/cm3 |
Conversion of the concentration from mass% to mol/kg (moles of solute/kg of water = molality):
1 | 0.123 | 0.098 | 0.095 | 0.173 | 0.039 | 0.084 | 0.12 | 0.071 | 0.253 | 0.119 | 0.062 | 0.071 | 0.064 |
5 | 0.642 | 0.512 | 0.497 | 0.901 | 0.204 | 0.439 | 0.627 | 0.371 | 1.316 | 0.619 | 0.321 | 0.371 | 0.333 |
10 | 1.354 | 1.08 | 1.048 | 1.901 | 0.431 | 0.926 | 2.778 | 1.307 | 0.782 | 0.703 | |||
20 | 3.047 | 2.43 | 4.278 | 0.969 | 2.084 | 6.25 | 2.941 | 1.76 | 1.581 | ||||
30 | 5.224 | 4.165 | 3.572 | 10.715 | 5.042 | 2.711 | |||||||
40 | 6.479 | 5.557 | 16.668 | 7.844 | 4.216 | ||||||||
Molality at 20°C, given as mol/kg water |
Conversion of the concentration from mass% to mol/liter (moles of solute/liter of solution = molarity):
1 | 0.122 | 0.098 | 0.095 | 0.172 | 0.039 | 0.084 | 0.12 | 0.071 | 0.252 | 0.118 | 0.062 | 0.071 | 0.064 |
5 | 0.624 | 0.504 | 0.495 | 0.885 | 0.2 | 0.432 | 0.615 | 0.369 | 1.317 | 0.607 | 0.323 | 0.367 | 0.329 |
10 | 1.279 | 1.05 | 1.041 | 1.832 | 0.415 | 0.896 | 2.772 | 1.256 | 0.768 | 0.685 | |||
20 | 2.694 | 2.283 | 3.928 | 0.891 | 1.93 | 6.096 | 2.6989 | 1.677 | 1.485 | ||||
30 | 4.243 | 3.744 | 3.123 | 9.958 | 4.326 | 2.417 | |||||||
40 | 5.496 | 4.499 | 14.3 | 6.2 | 3.48 | ||||||||
Molarity at 20°C, given as mol/l solution |
API expresses the gravity or density of liquid petroleum products. Online API to Specific Gravity calculator.
Calculator and formulas for conversion between different units of concentration: Molarity, molality, mole fraction, weight percent of solute and grams of solute per liter of solution - descriptive terms for solubility.
An introduction to density, specific weight and specific gravity.
It is possible to estimate the density of a liquid-liquid solution from the density of the solute and the solvent. However, due to shrinkage, the estimate will be a bit too low.
Specific gravities of liquids like alcohol, oils, benzene, water and many more.
Densities of selected solids.
Definitions and examples of how to calculate wt%, molarity and how to prepare dilutions.
