API Gravity: Definition, Calculation, and Converter
API gravity express the gravity or density of crude oil and liquid petroleum products. API is devised jointly by the American Petroleum Institute and the NIST - National Institute of Standards and Technology . The measuring scale is calibrated in terms of degrees API.
API Gravity can be calculated as:
°API = (141.5 / SG) - 131.5 (1)
°API = Degrees API Gravity
SG = Specific Gravity (at 60 oF)
Specific gravity can be calculated from API gravity:
SG = 141.5 / (°API + 131.5) (2)
Note! Oil with the least specific gravity has the highest API gravity
SG - API Converter
Density is a temperature depedent property. API gravity increases with increasing temperature, while specific gravity decreases with increasing temperature. See correlations at Density of crude oil as function of temperature . This means that the volume of a petroleum liquid increases with increasing temperature, and that a density number always must be given with the measurement temperature. The standard measuring temperature is 15°C or 60°F.
See also Standard test methods (ASTM and others) for crude oil properties, and temperature correlations for lubricating oil, fuel oils and jet fuel.
| Degree API | Specific Gravity | Weight | |
| (lb/US gal) | (kg/m3) | ||
| 1 | 1.068 | 8.894 | 1067 |
| 5 | 1.037 | 8.633 | 1035 |
| 8 | 1.014 | 8.447 | 1013 |
| 10 | 1.000 | 8.328 | 998.9 |
| 15 | 0.9659 | 8.044 | 964.8 |
| 20 | 0.9340 | 7.778 | 933.1 |
| 25 | 0.9042 | 7.530 | 903.2 |
| 30 | 0.8762 | 7.297 | 875.3 |
| 35 | 0.8498 | 7.078 | 848.9 |
| 40 | 0.8251 | 6.871 | 824.3 |
| 45 | 0.8017 | 6.677 | 800.8 |
| 50 | 0.7796 | 6.493 | 778.8 |
| 55 | 0.7587 | 6.319 | 757.9 |
| 60 | 0.7389 | 6.154 | 738.1 |
| 70 | 0.7022 | 5.848 | 701.5 |
| 80 | 0.6690 | 5.572 | 668.3 |
| 90 | 0.6388 | 5.320 | 638.1 |
- There is no clear definition of the different classes of crude oil; extra heavy oil (bitumen), heavy oil, medium oil, light oil, condensate. Different sources and different countries use their own limits. The boxes in the figure indicate the most common ranges used.
• Combustion
• Densities
API - American Petroleum Institute
The American Petroleum Institute - API.
Baume's Hydrometer
Liquid density with Degree Baume vs. Specific Gravity.
Crude Oil Properties - Standard test methods (ASTM and others)
An overview of common test methods and typical ranges of variation of petroleum quality parameters. What, why and how do the different test?
Crude Oil Viscosity vs. Gravity
Viscosity at 20°C/68°F and 50°C/122°F for more than 120 crudes is shown as function of specific gravity@15°C/60°F.
Engine & Gear Oil - Recommended Viscosity vs. Outside Temperature
Oil viscosity vs. temperature.
Grease - Temperature Limits
Temperature limits for grease - a combination of oil and thickener.
Hydrocarbon Mixtures - Average Boiling Points vs. Gravity and Molecular Weights
Formulas and examples of calculation of boiling point of hydrocarbon mixtures from gravity and molecular weight.
Hydrocarbon Mixtures - Molecular Weight vs. Gravity and Average Boiling Point
Formulas and examples of calculation of average molecular weight of hydrocarbon mixtures from gravity and average boiling point, achieved from distillation data.
Hydrocarbons - Physical Data
Liquid Densities
Liquids - Specific Gravities
Specific gravities for common fluids like acetone, alcohol, turpentine, oil and more.
Petroleum Products - Standard Test Methods (ASTM and others) and Specifications
An overview of common test methods and specifications of petroleum fuels. What, why and how do the different test?
Viscosities and densities of SAE Grade oils.
Yield Structure of Crude Oils with Increasing Density of Crude
Yields of different crude oil distillation cuts are plotted as function of whole crude specific gravity. Fractions based on European and North American markets, and the typical differences in crude oil fractionation in the two markets are also shown.
