Engine & Gear Oil - Recommended Viscosity vs. Outside Temperature
All lubricants have practical limits when it comes to operating temperatures.
- Lower temperatures and increased viscosity may restrict lubrication - causing metal to metal contact and damage to the machines
- Higher temperatures and reduced viscosity may limit lubrication film thickness - causing metal to metal contact and damage to the machines
For most machines - like car engines - the critical point of operation is at startup before reaching operating temperatures. In cold weather lubricants with adequate viscosities at start up temperature are required.
Engine Oil
The table below indicates appropriate engine oil viscosity vs. outside (start up) temperatures.
Engine Oil SAE Viscosity | Temperature | ||||||
-20 oF (-29 oC) | 0 oF (-17.8 oC) | 20 oF (-6.7 oC) | 40 oF (4.4 oC) | 60 oF (15.6 oC) | 80 oF (26.7 oC) | 100 oF (37.8 oC) | |
20W-20 | |||||||
20W-40 | |||||||
20W-50 | |||||||
10W-30 | |||||||
10W-40 | |||||||
10W | |||||||
5W-30 | |||||||
5W-20 |
Note that machine operating temperatures - and lubricant temperatures - does not change significantly with different ambient temperatures. In most cases operating temperatures of engines are above the temperatures in the table above.
Gear Oil
The table below indicates recommended gear oil viscosity vs. outside (start up) temperatures.
75W | |||||||
80W | |||||||
80W-90 | |||||||
85W | |||||||
90 | |||||||
140 |
Note that the tables above indicates average data. For specific information - check manufacturing data.
• Viscosities
API Gravity: Definition, Calculation, and Converter
API expresses the gravity or density of liquid petroleum products. Online API to Specific Gravity calculator.
Efficiency of Small Machine Elements
Friction and efficiency in bearings and roller chains.
Industrial Lubricants - Viscosities vs. ISO-VG Grade
ISO-VG viscosity grades for industrial lubricants.
Liquids - Dynamic Viscosities
Absolute (dynamic) viscosity values for some common fluids.
Motor Oils - Dynamic Viscosities
Dynamic viscosities for motor oils SAE 10 to 50 for temperatures ranging 0-100 oC.
Oil Fuels - Viscosities vs. Temperatures
Viscosities of fuel oils vs. temperature.
Oil Pipes - Pressure Loss vs. Oil Flow
Pressure drop in oil pipes - viscosities ranging 100 - 600 Saybolt Universal Seconds.
Oil Viscosity Converter
Convert between commonly used oil viscosity units.
Viscosities and densities of SAE Grade oils.
Viscosity Converter: Convert Between Dynamic & Kinematic Viscosity
