Efficiency of Small Machine Elements
Typical efficiencies of well lubricated small machine elements:
- ordinary bearings : 95 - 98%
- roller bearings : 98%
- ball bearings : 99%
- spur gears with cut teeth including bearings : 99%
- bevel gears with cut teeth including bearings : 98%
- belts : 96 - 98%
- high-class silent power transmission chain : 97 - 99%
- roller chains : 95 - 97%
- bicycle derailer : 87 - 97%
- bicycle gear hub : 86 - 95%
• Mechanics
Belt driven Fans - Fan vs. Motor Speed
Fan vs. motor speed in belt driven fans.
Belts - Power Transmission and Efficiency
Calculate belts power transmission and efficiency
Electric Motors - Efficiency
Engine & Gear Oil - Recommended Viscosity vs. Outside Temperature
Oil viscosity vs. temperature.
Friction - Friction Coefficients and Calculator
Friction theory with calculator and friction coefficients for combinations of materials like ice, aluminum, steel, graphite and many more.
Gear Trains - Bicycle Gearing Calculator
Gear train transmissions - bicycle gearing.
Gears
Gears effort force vs. load force.
Industrial Lubricants - Viscosities vs. ISO-VG Grade
ISO-VG viscosity grades for industrial lubricants.
Rolling Resistance
Rolling friction and rolling resistance.
