Gears
A gear is a mechanical device that transmits rotary motion by changing the magnitude and line of action of the effort force.
The effort force can be expressed as
F = W (r1 r2.. rn ) / (R1 R2.. Rn ) (1)
F = effort force (N, lbf )
W = load force or weight (N, lbf )
r = gear wheel inside diameter (m, in)
R = gear wheel outside diameter (m, in)
Example - Gear Transmission and Effort Force
The effort force in a gear transmission with three wheels:
- wheel 1 : r1 = 0.05, R1 = 0.12
- wheel 2 : r2= 0.06, R2= 0.13
- wheel 3 : r3 = 0.07, R3 = 0.14
and a weight load of 1000 N can be calculated as
F = W (r1 r2rn ) / (R1 R2Rn )
= (1000 N) ((0.05 m) (0.06 m) (0.07 m)) / ((0.12 m) (0.13 m) (0.14 m))
= 96 N
= 0.1 kN
• Mechanics
Belts - Pulley Diameters vs. Speed
The pulley laws - driver and driven - diameter and rpm
Conn-Rod Mechanism
The connecting rod mechanism.
Efficiency of Small Machine Elements
Friction and efficiency in bearings and roller chains.
Force
Force Ratio
The force ratio is the load force versus the effort force.
Gear Reducing Formulas
Output torque, speed and horsepower with gears.
Gear Trains - Bicycle Gearing Calculator
Gear train transmissions - bicycle gearing.
Mass vs. Weight
Toggle Joint
A toggle joint mechanism can be used to multiply force.
