Gear Reducing Formulas
Gear Output Torque
Mo = Mi r μ                               (1)
Mo = output torque (Nm, lbf ft)
Mi = input torque (Nm, lbf ft)
r = gear transmission ratio
μ = gear efficiency (%)
Example - Geear Output Torque
The output torque from a transmission with input torque 500 Nm, gear transmission ratio 3.8 and gear efficiency 0.9 - can be calculated as
Mo = (500 Nm) (3.8) (0.9)
    = 1710 Nm
Gear Output Speed
So = Si  / r                             (2)
So = output speed (rad/s, rpm)
Si = input speed (rad/s, rpm)
Example - Gear Output Speed
The output speed of a transmission with input speed 2000 rpm and transmission ratio 3.8 can be calculated as
So = (2000 rpm) / (3.8)
    = 526 rpm
Gear Output Horsepower
Po = Pi  μ                              (3)
Po = output horsepower (W, hp)
Pi = input horsepower (W, hp)
Example - Gear Output Power
The output power from a transmission with input power 300 kW and efficiency 0.9 can be calculated as
Po = (300 kW) (0.9)
    = 270 kW
Mechanics
Belts - Pulley Diameters vs. Speed
The pulley laws - driver and driven - diameter and rpm
Conn-Rod Mechanism
The connecting rod mechanism.
Force Ratio
The force ratio is the load force versus the effort force.
Gear Trains - Bicycle Gearing Calculator
Gear train transmissions - bicycle gearing.
Gears
Gears effort force vs. load force.
Improvised Torque Wrench
Toggle Joint
A toggle joint mechanism can be used to multiply force.
