Force Ratio
A machine is a device that can change the magnitude and line of the action of force.
Examples of machines are
- pulley systems
- gear systems
- screw-jacks
A simple machine amplifies the input (effort) force to a larger output (load) force. The force ratio can be expressed as
Fr = F / S (1)
Fr = force ratio - mechanical advantage
F = load force (N, lbf)
S = effort force (N, lbf)
Example - Force Ratio for Pulley
The effort force for a pulley with 4 ropes, no friction loss (μ = 1) and load 100 kg is calculated to 245 N.
The force ratio can be estimated to
Fr = (100 kg) (9.81 m/s2) / (245 N)
= 4
• Mechanics
Acceleration of gravity and Newton's Second Law - SI and Imperial units.
Bodies Moving on Inclined Planes - Acting Forces
Required forces to move bodies up inclined planes.
Centripetal and Centrifugal Acceleration Force
Forces due to circular motion and centripetal / centrifugal acceleration.
Equilibrant Force
The force required to keep a system of forces in equilibrium.
Force
Forces Acting on a Wedge
Large forces can be introduced with the aid of wedges.
Gear Reducing Formulas
Output torque, speed and horsepower with gears.
Gears
Gears effort force vs. load force.
Hydraulic Force vs. Pressure and Cylinder Size
Calculate hydraulic cylinder force.
Impulse and Impulse Force
Forces acting a very short time are called impulse forces.
Levers
Use levers to magnify forces.
Motors - Speed vs. Pulley Diameter
Pulley (Sheave) selection charts for motors ranging 850 - 3450 rpm.
Movement Ratio
Machines and movement ratio (velocity ratio).
Pneumatic Cylinder - Excerted Force vs. Pressure
Force excerted by pneumatic air cylinders vs. air pressure cylinder size - online calculator.
Pulleys
Pulleys, blocks and tackles.
Screw Jack - Effort Force vs. Load
Screw jacks and effort forces.
Toggle Joint
A toggle joint mechanism can be used to multiply force.
