Screw Jack - Effort Force vs. Load
A screw jack is a mechanical device that can increase the magnitude of an effort force.
The effort force for a screw jack when neglecting friction can be expressed as
F = (Q p) / (2 π R)                                 (1)
F = effort force at the end of the arm or handle (lb, N)
Q = weight or load (lb, N)
p = pitch - distance or lead of thread in one turn  (in, m)
R = lever-arm radius (in, m)
Pitch is the distance between screw grooves and is commonly used with inch sized products and specified as threads per inch. Lead is the linear travel the nut makes per one screw revolution. The pitch and lead are equal.
The torque acting on the screw can be calculated as
T = F R                                 (2)
T = torque (lb in, Nm)
Example - Screw jack without friction
If the load on a screw jack is 50000 lb, the lever-arm is 20 inches and the pitch equals 1/8 inches - the effort force can be estimated to
F = ((50000 lb) (1/8 in)) / (2 π (20 in))
    = 49.8 lb
T = (49.8 lb) (20 in)
    = 995 lb in
    = 82.9 lb ft
Example - Metric Screw Lift
A M24 metric screw with pitch 3 mm is used in a mechanical screw lift with load 225 kN. The lever arm is 0.5 m. The effort force required can be calculated as
F = ((225000 N) (0.003 m)) / (2 π (0.5 m))
    = 215 N
T = (215 N) (0.5 m)
    = 107 Nm
Screw Jack Calculator - without Friction - Imperial Units
Calculate torque and effort force acting on the lever arm.
Screw Jack Calculator - without Friction - Metric Units
Note the difference between mass and weight!
Screw Jack with Friction
For motion in the same direction as the load (load assist the screw jack), the effort force can expressed as
F = Q ((2 π μ r - p) / (2 π r + μ p)) (r / R)                                   (2)
r = pitch radius of screw (in)
μ = friction coefficient
For motion in the opposite direction as the load (load resists the screw jack), the effort force can expressed as
F = Q ((2 π μ r + p) / (2 π r - μ p)) (r / R)                                 (3)
Mechanics
Statics
Force Ratio
The force ratio is the load force versus the effort force.
Forces Acting on a Wedge
Large forces can be introduced with the aid of wedges.
Friction - Coefficients for Common Materials and Surfaces
Find friction coefficients for various material combinations, including static and kinetic friction values. Useful for engineering, physics, and mechanical design applications.
Improvised Torque Wrench
Levers
Use levers to magnify forces.
Lifting Wheels
Loads and effort force with lifting wheels.
Movement Ratio
Machines and movement ratio (velocity ratio).
Piston Engines - Displacement
Calculate piston engine displacement.
Shackles - Safe Loads
Safe loads of shackles.
Toggle Joint
A toggle joint mechanism can be used to multiply force.
