Piston Engines - Displacement
The displacement of a piston engine can be calculated as
V = (π / 4) s b2 noc (1)
V = engine displacement (in3, cm3)
s = stroke (in, cm)
b = bore diameter (in, cm)
noc = number of cylinders
Example - Displacement of V8 Engine
The displacement of a 8 cylinder piston engine with stroke 3.31 in and bore 3.625 in can be calculated as
V = (π / 4) (3.31 in) (3.625 in)2 (8)
= 273 cu in
Piston Engine Displacement Calculator
Acceleration
Change in velocity vs. time used.
Car - Required Power and Torque
Power, torque, efficiency and wheel force acting on a car.
Car - Traction Force
Adhesion and tractive force between car wheel and surface.
Car Acceleration
Car acceleration calculator.
Cars - New vs. Old Car Cost Calculator
Calculate and compare the costs between owning a new vs. an old car.
CO2 Calculator - Emissions from Cars
Calculator for CO2 emissions from different kind of cars (gasoline, diesel, LPG, electrical), comparing with alternative forms of transportation (as airplane, bus and train).
Disk Brakes - Torque and Force
Forces and torque activated with disk brakes.
Distance Traveled vs. Speed and Time - Calculator and Chart
Velocity plotted in time used diagram.
Drag Coefficient
The drag coefficient quantifies the drag or resistance of an object in a fluid environment.
Driving Distances between European Cities
Driving distance between some major European cities.
Flash Points - Liquids
The flash points for some common liquids and fuels.
Fuel Consumption - mpg
Calculate fuel consumption in miles per gallon - mpg - calculator and consumption charts.
Garage Ventilation
Exhaust ventilation from garages and workshops.
Impact Force
Improvised Torque Wrench
Piston Engines - Compression Ratios
Cylinder volume and compression ratios in piston engines.
Rolling Resistance
Rolling friction and rolling resistance.
Screw Jack - Effort Force vs. Load
Screw jacks and effort forces.
Vehicle - Distance Traveled vs. Velocity and Time (km/h)
Speed (km/h) vs. time (hours) and distance traveled (km).
Vehicles Traffic Flow and Density
Traffic flow and density as used in highway design.
