Vehicles Traffic Flow and Density
Vehicle Traffic Flow
The vehicle traffic flow on a road can be expressed
q = n 3600 / t (1)
q = vehicle flow (no. vehicles per hour)
n = no. vehicles passing in t seconds
t = time for passing vehicles (s)
Example - Vehicle Traffic Flow
If 1000 vehicles passes in 2 hours (7200 s) - the flow can be calculated
q = (1000 vehicles) (3600 s/h) / (7200 s)
= 500 vehicles/h
Vehicle Density
Vehicle density can be expressed as
k = n 5280 / l (2)
k = vehicle density (vehicles per mile)
n = no. of vehicles occupying a length l of the road
l = the length of road occupied by the vehicles (ft)
(2) expressed in km
k = n 1000 / l (2b)
k = vehicles per km
l = the length of road occupied by the vehicles (m)
Banked Turn
A turn or change of direction in which the vehicle banks or inclines, usually towards the inside of the turn.
Car - Required Power and Torque
Power, torque, efficiency and wheel force acting on a car.
Car - Traction Force
Adhesion and tractive force between car wheel and surface.
Car Acceleration
Car acceleration calculator.
Centripetal and Centrifugal Acceleration Force
Forces due to circular motion and centripetal / centrifugal acceleration.
New vs. Old Car Costs: A Comprehensive Cost Comparison
Compare the total cost of owning a new car versus an old car, including purchase price, maintenance, fuel efficiency, insurance, and depreciation. Use our detailed breakdown to make an informed financial decision before buying the next vehicle.
Noise generated by Road Traffic
Estimate noise level generated by traffic.
Piston Engines - Compression Ratios
Cylinder volume and compression ratios in piston engines.
Piston Engines - Displacement
Calculate piston engine displacement.
Rolling Resistance
Rolling friction and rolling resistance.
Slope Calculator: Convert Between Degrees, Gradient, and Grade
Convert slopes pitch between degrees, gradients and grades.
