Piston Engines - Compression Ratios
The static compression ratio in a piston engine is the ratio between the volume of the combustion chamber when the piston in the cylinder is at the bottom of its stroke and the volume of the combustion chamber when the piston is at the top of its stroke. It can be expressed as
CR = (Vd + Vc) / Vc
= (π d2 s / 4 + Vc) / Vc (1)
CR = compression ratio
Vd = piston displacement volume - total volume swept by the piston (cm3, in3)
Vc = clearence volume - volume left in the cylinder when the pistion is at the top dead center (cm3, in3)
d = piston diameter (cm, in)
s = piston stroke (cm, in)
12 Volt - Electric Automotive Wiring
Maximum wire lengths vs. currents in the 12 volt electrical system of a car.
12 Volt - Maximum Wire Length vs. Current
Maximum length of copper wire with 2% voltage drop.
Acceleration Units Converter
Converting between units of acceleration.
Average Velocity
Distance traveled vs. time used.
Car - Required Power and Torque
Power, torque, efficiency and wheel force acting on a car.
Car - Traction Force
Adhesion and tractive force between car wheel and surface.
Car Acceleration
Car acceleration calculator.
Car Fuel Consumption - liter/100 km
Calculate fuel consumption in liter per km - consumption chart and calculator.
Centripetal and Centrifugal Acceleration Force
Forces due to circular motion and centripetal / centrifugal acceleration.
CO2 Calculator - Emissions from Cars
Calculator for CO2 emissions from different kind of cars (gasoline, diesel, LPG, electrical), comparing with alternative forms of transportation (as airplane, bus and train).
Compressed Air vs. Free Air - Compression Ratio
The ratio of compressed air pressure to free air pressure.
Drag Coefficient
The drag coefficient quantifies the drag or resistance of an object in a fluid environment.
Electrical Vehicle Charging - Power vs. Voltage and Amps
EV Charging - AC vs. DC, single phase vs. three phase and power vs. voltage and amps.
Garage Ventilation
Exhaust ventilation from garages and workshops.
Impact Force
New vs. Old Car Costs: A Comprehensive Cost Comparison
Compare the total cost of owning a new car versus an old car, including purchase price, maintenance, fuel efficiency, insurance, and depreciation. Use our detailed breakdown to make an informed financial decision before buying the next vehicle.
Piston Engines - Displacement
Calculate piston engine displacement.
Reliability of Machine Components
Mean Time Between Failure - MTB and reliability of machine components and systems.
Rolling Resistance
Rolling friction and rolling resistance.
Vehicle - Distance Traveled vs. Velocity and Time (km/h)
Speed (km/h) vs. time (hours) and distance traveled (km).
Vehicles Traffic Flow and Density
Traffic flow and density as used in highway design.
