Acceleration Units Converter
Acceleration is the ratio change of velocity to change in time - and can be expressed as
a = dv / dt (1)
a = acceleration (m/s2, ft/s2)
dv = v1 - v0 = change in velocity (m/s, ft/s)
dt = t1 - t0 = time taken to change the velocity (s)
Online Units Acceleration Calculator
The calculator below can be used to convert between some common acceleration units:
Download and print Acceleration vs. Change in Velocity and Time chart - km/h and m/s2
Download and print Acceleration vs. Change in Velocity and Time chart - mph and ft/s2
Example - Acceleration of a Car
A car accelerates from 0 km/h(0 m/s) to 100 km/h(27.8 m/s) in 5 seconds. The acceleration can be calculated by using km/h as the units for velocity:
a = ((100 km/h) - (0 km/h)) (1000 m/km) (1/3600 h/s) / (5 s)
= 5.6 m/s2
The calculation can be simplified by using m/s as the units for velocity:
a = ((27.8 m/s) - (0 km/h)) / (5 s)
= 5.6 m/s2
• Basics
• Dynamics
• Mechanics
Acceleration
Change in velocity vs. time used.
Acceleration of gravity and Newton's Second Law - SI and Imperial units.
Acceleration vs. Velocity Equations
Useful equations related to acceleration, average velocity, final velocity and distance traveled.
Banked Turn
A turn or change of direction in which the vehicle banks or inclines, usually towards the inside of the turn.
Car Acceleration
Car acceleration calculator.
Centripetal and Centrifugal Acceleration Force
Forces due to circular motion and centripetal / centrifugal acceleration.
Disk Brakes - Torque and Force
Forces and torque activated with disk brakes.
Force
Mass vs. Weight
New vs. Old Car Costs: A Comprehensive Cost Comparison
Compare the total cost of owning a new car versus an old car, including purchase price, maintenance, fuel efficiency, insurance, and depreciation. Use our detailed breakdown to make an informed financial decision before buying the next vehicle.
Piston Engines - Compression Ratios
Cylinder volume and compression ratios in piston engines.
Unit Factor Method
Velocity Units - Online Converter
Convert between common velocity and speed units.
