Linear Motion Formulas
Average velocity/speed of a moving object can be calculated as
v = s / t                            (1a)
v = velocity or speed (m/s, ft/s)
s = linear distance traveled (m, ft)
t = time (s)
  • distance is the length of the path a body follows in moving from one point to another - displacement is the straight line distance between the initial and final positions of the body
  • we use velocity and speed interchangeable - but be aware that speed is a measure of how fast or slow a distance is covered, the rate at which distance is covered - velocity is a vector, specifying how fast or slow a distance is covered and the direction
If acceleration is constant then velocity can be expressed as:
v = v0 + a t                            (1b)
v0 = initial linear velocity (m/s, ft/s)
a = acceleration (m/s2, ft/s2)
Linear distance can be expressed as (if acceleration is constant):
s = v0 t + 1/2 a t2(1c)
Combining 1b and 1c to express the final velocity
v = (v02+ 2 a s) 1/2 (1d)
Velocity can be expressed as (velocity is variable)
v = ds / dt (1f)
ds = change in distance (m, ft)
dt = change in time (s)
Acceleration can be expressed as
a = dv / dt                                   (1g)
dv = change in velocity (m/s, ft/s)
Example - a Marathon Run
If a marathon - 42195 m - is run in amazing 2:03:23 (7403 seconds) (Wilson Kipsang, Kenya - September 29, 2013 Berlin Marathon) - the average speed can be calculated
v = (42195 m) / (7403 s)
= 5.7 m/s
= 20.5 km/h
Example - Acceleration of a Car
A car accelerates from 0 km/h to 100 km/h in 10 seconds . The acceleration can be calculated by transforming (1b) to
a = (v - v0 ) / t
= ( (100 km/h) (1000 m/km) / (3600 s/h) - (0 km/h) ( 1000 m/km) / (3600 s/h) ) / (10 s)
= 2.78 (m/s2)
Linear Motion Calculators
Average velocity
Distance
Final Velocity
Acceleration
Circular Motion - Rotation
Angular Velocity
Angular velocity can be expressed as (angular velocity = constant):
ω = θ / t                           (2)
ω = angular velocity ( rad /s)
θ = angular distance ( rad )
t = time (s)
Angular velocity and rpm:
ω = 2 π n / 60                        (2a)
n = revolutions per minute (rpm)
π = 3.14...
The tangential velocity of a point in angular velocity - in metric or imperial units like m/s or ft/s - can be calculated as
v = ω r (2b)
v = tangential velocity (m/s, ft/s, in/s)
r = distance from center to the point (m, ft, in)
Example - Tangential Velocity of a Bicycle Tire
A 26 inches bicycle wheel rotates with an angular velocity of π radians/s (0.5 turn per second) . The tangential velocity of the tire can be calculated as
v = ( π radians/s ) ((26 inches) / 2)
= 40.8 inches/s
Angular Velocity and Acceleration
Angular velocity can also be expressed as (angular acceleration = constant):
ω = ω o + α t                               (2c)
ω o = angular velocity at time zero ( rad /s)
α = angular acceleration or deceleration (rad/s2)
Angular Displacement
Angular distance can be expressed as (angular acceleration is constant):
θ = ω o t + 1/2 α t2(2d)
Combining 2a and 2c:
ω = (ω o 2+ 2 α θ) 1/2
Angular Acceleration
Angular acceleration can be expressed as:
α = dω / dt = d2θ / dt2(2e)
dθ = change of angular distance (rad)
Example - Flywheel Deceleration
By Geni (Photo by User:geni) [ GFDL or CC-BY-SA-3.0-2.5-2.0-1.0 ], via Wikimedia Commons
A flywheel is slowed down from 2000 rpm ( revolutions /min) to 1800 rpm in 10 s . The deceleration of the flywheel can be calculated as
α = ((2000 rev/min )  - (1800 rev/min )) (0.01667 min/s) (2 π rad / rev ) / (10 s)
= 2.1 rad /s2
= (2.1 rad/s2) (360 / (2 π) degrees/rad)
= 120 degrees/s2
Angular Moment - or Torque
Angular moment or torque can be expressed as:
T = α I                                 (2f)
T = angular moment or torque (N m)
I = Moment of inertia (lbm ft2, kg m2)
Dynamics
Mechanics
Acceleration
Change in velocity vs. time used.
Acceleration Units Converter
Converting between units of acceleration.
Angular Motion - Power and Torque
Angular velocity and acceleration vs. power and torque.
Banked Turn
A turn or change of direction in which the vehicle banks or inclines, usually towards the inside of the turn.
Car - Required Power and Torque
Power, torque, efficiency and wheel force acting on a car.
Car Acceleration
Car acceleration calculator.
Centripetal and Centrifugal Acceleration Force
Forces due to circular motion and centripetal / centrifugal acceleration.
Conn-Rod Mechanism
The connecting rod mechanism.
Conservation of Momentum
The momentum of a body is the product of its mass and velocity - recoil calculator.
Disk Brakes - Torque and Force
Forces and torque activated with disk brakes.
Distance Traveled vs. Speed and Time - Calculator and Chart
Velocity plotted in time used diagram.
Elevators - Force and Power
Required force and power to lift an elevator.
Flywheels - Kinetic Energy
The kinetic energy stored in flywheels - the moment of inertia.
Impulse and Impulse Force
Forces acting a very short time are called impulse forces.
Kinetic Energy
Energy possessed by an object's motion is kinetic energy.
Piston Engines - Displacement
Calculate piston engine displacement.
Projectile Range
Calculate the range of a projectile - a motion in two dimensions.
Radians vs. Degrees
Rolling Resistance
Rolling friction and rolling resistance.
Vehicle - Distance Traveled vs. Velcocity and Time Used (mph)
Speed (mph) and time (hours) and distance traveled (miles) chart.
Vehicle - Distance Traveled vs. Velocity and Time (km/h)
Speed (km/h) vs. time (hours) and distance traveled (km).
Velocity Units Converter
Convert between speed and velocity units like m/s, km/h, knots, mph and ft/s.
